gaz832 7 1 Cars Posted September 3, 2011 hey fols, having probs with the car again, last week the car gave up on me , so i changed the fuel pump and put the hoses on the correct way round , tried to start it but no fuel to engine, so i chandged the hoses aroud but still no fuel, fuel is pumping but not going to engine, could i have a blockage somewhere, only thing i havent chandged is the fuel filter could this be totally blocked and stop letting petrol though. Share this post Link to post Share on other sites
omega 82 Posted September 3, 2011 hey fols, having probs with the car again, last week the car gave up on me , so i changed the fuel pump and put the hoses on the correct way round , tried to start it but no fuel to engine, so i chandged the hoses aroud but still no fuel, fuel is pumping but not going to engine, could i have a blockage somewhere, only thing i havent chandged is the fuel filter could this be totally blocked and stop letting petrol though. think you have ansered your own question! Share this post Link to post Share on other sites
gaz832 7 1 Cars Posted September 3, 2011 anyone got an ideea to sort this, or had this similar problem . Share this post Link to post Share on other sites
harryskid 193 Posted September 3, 2011 think you have ansered your own question! As he says! Share this post Link to post Share on other sites
GLPoomobile 958 Posted September 3, 2011 Disconnect the hose from the bottom of the filter. If you've got fuel pumping through there, but nothing after the filter, then that's your problem. If you've got nothing pumping out even before the filter, trace it back further. Share this post Link to post Share on other sites
gaz832 7 1 Cars Posted September 4, 2011 got fuel going to the engine now, now the damn thing wont fire into life. gotta love the 205. Share this post Link to post Share on other sites
harryskid 193 Posted September 5, 2011 got fuel going to the engine now, now the damn thing wont fire into life. gotta love the 205. Where was the blockage? Share this post Link to post Share on other sites
gaz832 7 1 Cars Posted September 5, 2011 in the fuel lines mate. once i got petrol to the engine ,there was loads of prssure to it, actually blew the hose off the regulator. . now it wont turn over. . i recently removed a aftermarket steroe and put the origional clarion in, dont know if ive cut a wire wrong or not, as it was starting before i took it out. now it wont fire up, turns over no bother . checked the plugs just had new leads, but it was playing up lately. new rotor and coil time a think. Share this post Link to post Share on other sites
gaz832 7 1 Cars Posted September 5, 2011 should petrol stay filled up in the regulator if its not starting, . just thought if the fuel rail is clogged up now. Share this post Link to post Share on other sites
Mark Greenwood 0 Posted September 7, 2011 should petrol stay filled up in the regulator if its not starting, . just thought if the fuel rail is clogged up now. the pressure will stay there yes when you say it will not turn over, do you mean physically..? Has it filled the bores with fuel? Share this post Link to post Share on other sites
dcc 855 Posted September 18, 2011 double check your fuel pressure regulator. if its not working at 3bar (from memory so dont hate on a player for wrong info) the injectors wont feed enough fuel into the engine Share this post Link to post Share on other sites
