chipstick
General Purpose Loctite
allye
I didn't use thread lock on the oil filter stud, no problems so far, just sure oil filter was on securely. I got rid of the heat exchanger too.
S@m
Same here.
chipstick
I'm presuming everyone who is successful with the change is using the same adapter? Part number 1103 54
SurGie
Will be checking tomorrow if I have put a sufficient amount on the thread that it does not come out when I undo the filter :)
Remember to use either panel wipe or methylated spirit around the threads, so the thread lock will stick properly.
chipstick
Another new tip learnt. Will petrol/brake cleaner suffice? :lol:
S@m
Thats the one!
Thats the one!
Luckily all the 205's in Australia had A/C and are thus fitted with remote filters as per below. #15 is 1103 54
NeilGTi85
Pop your findings in here. I am going to aim for half in the block with loctite. Half poking out and go from there.
Just to let you know, the oil resistant loctite did the job.
I unscrewed the filter and the thread did not move, tryed to wind it by hand but it seemed pretty stuck!
SurGie
I pre tested mine a while ago and the oil filter came off the thread without the need for loctite, but im still going to use some because when the filter has been on for a while it could make the thread come out.
