zebedy101
Supercharged 205's
zebedy101
Evening all,
I've been thinking about this for a while now, really love the idea of a charged 205 but not really sure how good it would be or weather it would just be overkill on a good car? Just after some opinions really and a bit of info. I'd be looking at using a Gti6 engine and Lynx kit.
Some will remember I previously had a 205 Gti6 and sold that around a year ago. Had a couple of Celica Gt4's after I sold that and now am driving a 200sx. The 200sx is great fun so I may well keep that as a daily driver plus I've only had it for about 3 weeks but have spent 3 weeks getting it up to spec (they are rubbish standard)
I keep hankering after another 205 and want a proper balls out one really, something to have a laugh in on a Sunday.
All advice and opinions welcome.
Thanks, Seb
Batfink
I think the lynx kit is a very good idea..
Steve (Daxed) has one, Couple of others too which I cannot think of there names off hand,
Lynx is the kit to have, a couple of other's have copied the idea so make sure you get the right one
rallyeash
spiky's got a gti6 sc 205 track car. look for his project thread...
Masekwm
Seems like an appropriate topic...
Wouldn't the power require major mods though to include:-
brakes - GTi6 wouldn't be enough?
suspension - going to need a very good set up?
diff?
So at new prices you are taking 5k minimum + the 205 GTi6.
rallyeash
gti6 brakes would be ok on a road car but 4 pots would be the better option for track and road
good suspension setup, even if its just a good set of bilsteins and eibachs or somthing.
yeah you'd want a diff, ideally a plate but a Quiafe atb is better than nothing!
Edited by rallyeash
I've driven a couple of low-boost supercharged 205 GTi-6's and they're very quick and impressive.
Perhaps more importantly if you're planning on using it daily or for road use, they are very well mannered and the power easily accessable- if drives really just like a standard 205 GTi-6 that's been pumped full of steroids, and thus starts and idles nicely, bumbles around in traffic fine, just goes like hell when you give it some stick.
The only disappointment for me is that it's a bit bland aurally, as there's none of the induction hammer that you get from ITB's nor the 6-pot growl that you get from a V6. I really am nit-picking though, as it's a comparitively minor thing and no worse than a typical 8v or Mi16 for example (standard GTi-6's do have a nice induction note, but it seems to be muted by the supercharger on the boosted cars)
I'm not personally convinced that you'll need to upgrade brakes/suspension beyond what you'd normally do so for your intended use - Steve (Daxed) for example has fairly standard suspension on it for example, and despite being below freezing and in the middle of winter when I drove it, it seemed to cope just fine on the road, although would likely be more out of its depths on the track. On the road brakes should be fine unless you're driving like an idiot, although clearly for track use you're likely to want to do something given that you're going to be arriving at corners a whole lot quicker than you would have been and thus be scrubbing off more speed.
A diff is a useful addition to any 205 as far as I'm concerned, and the more power, the more beneficial it becomes (IMO)
Price wise it's expensive certainly, but it's that bad really when you compare it to the cost of getting over 200hp from the more convensional cams/bodies/ECU + mapping route.
Only thing that I can see that it would be useless for is if you want to enter the car in any form of competative motorsport.
madspikes
I've got a supercharged 8v that I use everyday.... and I certainly get that supercharger wine!
Mad.
allye
This is a very interesting read. This is very much in my future plans!
feb
Out of curiosity, what boost does the Lynx kit run and is it safe to use on a standard engine reliability wise?
What power do they make?
not a great deal of boost really, 0.6 bar low boost is 250 bhp / 215 lbft, run with a restrictor ring on the throttle body.
high boost requires low comp pistons forged rods and a larger restrictor ring, otherwise identical kit, 1.3 bar boost 400 bhp / 275 lbft.
feb
I think 250bhp on a car that weighs 900kg or so must be a lot of fun and plenty enough and you can "eat" modern hatches for breakfast :)
A real wolf in a sheep's clothing.
One day if I win the lottery, lol!
Edited by feb
zebedy101
Thanks for all the replies, made a good read especially Anthony's comments on experiences from behind the wheel of one. It may see a little track action but not nothing hardcore or competitive.
I'd probably be looking at using a 4 pot setup up front on the brakes and keeping with standard rear disc setup.
Suspension is something I haven't really thought about but I can't see the need for a massive spec as it will be used on the road mainly.
250bhp is what I'd be looking for anything extra would be too much for something that's 900kg's and used on the road IMO. I love the supercharger wine, a couple of years ago at Cadwell I saw a Gti6 that was supercharged and the noise I thought was great.
It's by no means a cheap conversion, when you add up the cost of throttle bodies against the cost of running a low boost supercharger then add up the gains it makes sense though. Dependent on intended use of course and personal preference.
Just go High boost as the 205 can handle it, Having been in some +/- 300bhp odd Turbo's 250 bhp seems slow,
You clearly have a very warped perspective on what a slow 205 is Miles :lol:
d7ve_b
Are there any kits available to charge an 8v?
McDude
I've always fancied getting the Eaton unit from a Mini Cooper S and putting that on an 8 valve. I know it's been done before, but I love the supercharger whine and the low down gruntiness.
Editted to say "Doh!" I think it was MadSpikes' 8 valver I'd seen. That is the Eaton unit isn't it? I just looked at your build pictures again - looks like a lot of work went into that.
Edited by McDude
Not a kit as such, but have a look at Madspike's thread - that's an 8v with a Mini sourced Eaton M45 :)
(and having been stood next to it at Pugfest when he fired it up, it certainly would satisfy your love of supercharger whine!)
Rolando
charged 205's are the way forward, i'm going high boost this winter for next summer :ph34r:
its a right ball ache hiding the intercooler unless you want it on show? i would say if your going to do it, do it right and dont cut any corners. i tried cutting corners and in the end it cost me more getting it right.
the only thing i think is rubbish is torque steer but i think i might change my tyres as it was fine with toyo's on but when i changed to yokos it seemed to pull all over the place and follow the camber of the road. and it seems to drink optimax like its going out of fashion as well so be ware its not cheap running them either.
Ro
zebedy101
Fuel consumption isnt a worry to be honest, old Gt4 did 16-19mpg at best so nothing new there. Although the 200sx doesn't use any petrol she'll happily do 25mpg and is capable of over 30 on a run.
Spiky
205's supercharged are great, and will potter around perfect,
i took mine out earlier fir the fist time in a while.
gti6 brakes will be fine
i have Lotus 2 pots and rc5+ pads and my brakes are beyond awesome, tinest pedal and the braking is very sharp
Masekwm
Spiky,
How did you do the pulley belt for the charger without the power steering pump?
Keith
Spiky
Just put a pas pump on not connected up, not failed o made any noises yet
Masekwm
Thanks, how hard is the conversion in the 205. I've read the guide for the 306, was it much harder?
Spiky
well i guess i have to say harder, as it's not as simple as the guide, but only as i didnt run my boost pipes the same way and i run the high boost intercooler, so i never have any ACT issues while on track
it's shoe horned in but, has been fine since i fitted it :)
