pugpete1108
Fuel System Plumbing
pugpete1108
just refitted my fuel lines and pump etc but can for the life of me remember what pipes are what from the fuel pump. im ok from the filter to the rail i think.
what one is the high pressure side?
cheers
filter is on the feed, return comes off the regulator
pugpete1108
yeah im cool with that bit just the pump end mainly.
what outlet on my pump is the feed? (its drawn looking down through the access hole)
cant remember specifically but i do recall seeing arrows on the takeoffs, dont know if they were on all years though
pugpete1108
i'll take a look see, cheers
Easiest way to be sure is direct a couple of lengths of fuel hose in to a bucket, then briefly power up the pump and see which one sends petrol out!
brumster
The one in the middle of the pump top is the feed (ie. the output from the pump). The one offset and not in the middle of the 'circle' is the return.
pugpete1108
spot on cheers :)
