johnnyboy666
Rover 25 Wont Start
johnnyboy666
Right, so in case it wasnt embarrassing enough that i was driving a rover, i then proceded to run out of petrol and spluttered to a stop. went and got a jerry can full and sloshed it in, but now it wont start! It'll turn over, just wont fire up at all
I thought it mightve been the immobilisor, so i manually reset that but still nothing
I'm wondering if i knackered the fuel pump or summit by running it dry?
Its a 1.4 spirit s
Daviewonder
It's a rover so it must be the head gasket :lol:
johnnyboy666
ha, that was my first check, cant seem to see any oil in the water or mayo
Daviewonder
It definately ran out of fuel? Any chance you hit a bump and tripped the fuel cut off?
johnnyboy666
um, its a possibility, how would i go about checking?
Pugleyrich
Quite common on these when you run out, apparently they need about £20 of petrol to start again. Not sure why, but seen it as a topic a couple times on the zr forum
Mikey S
fuel cutoff is in front off the bonnet switch just to the right of the master cylinder reservoir. give it a firm push down and it should click if its been tripped.
johnnyboy666
looks like i'd better get a bigger jerry can then lol, hope it works otherwise thats £20 down the sh!tter, having said that how much is £20worth these days?? or should it be 20 litres?
Lan
I would have thought its a good thing that it doesn't start as it means you don't have to drive it :D
on a side note though 20 quid definatly won't get you 20 litres now, when i put 20quids worth of super in my car i get 14 litres
johnnyboy666
yep i definately dont enjoy driving it trust me! possibly the very worst car i have ever driven, and thats before you even take into account that its a rover... having said that, the pug is on axle stands and the bus takes me 3hrs each day to get to work, so I dont have much choice! i think i'll just stick 20 litres in, if that doesnt work then I'll come up with a better plan!
Daviewonder
20 litres and a match?
johnnyboy666
I'll be honest i did contemplate pushing it to a dark alley and torching it rather than getting towed 6 or so miles home!
TaffyTim
It was a rover 25 that wrote off my first 205 gti, I have a spare match if you need one.
