Carl Chambers
[trackday_prep] Track Car Tidy Up An Tweaks
Carl Chambers
Well my miami 205 track has been built for over 3 years now and a few things needed doing and a few parts needed tidying
So first was engine out, rust treat and repaint engine bay. Fitted new clutch and a gearbox that wont crunch I hope, plus finally fitted my Quaife LSD.
The header tank and heater box has now all gone and a 106 GTi rad fitted so hopefully it will cool it enough still, new Mocal oil cooler;
New Compbrake rose jointed 309 wishbone and shafts, braided hoses, and new Bilstien shocks.
Then my home brewed fibre glass Auto bonnet with T16 vent which is a x-sport auto hump grafted on a Shenpar bonnet with a vent cut in.
As I had no luck finding a Dimma rear panel, I made my own T16 style rear grille, which took a lot of time to get right and I destroyed 3 front grilles doing it, its still not perfect but it looks ok,
Edited by GKZ 206
Carl Chambers
A fibre glass tailgate will be added and cut to suit.
Front valance and bumper cut to aid cooling and again in T16 style;
Carl Chambers
Then the bit I had been dreading, the roof!
This car when I first got it came with the factory sunroof, so I cut a roof skin from a scrap non sunroof 205 and grafted in on. This was put on top of the old one for ease mainly but this did mean now it had 2 roof shins instead of just one! This didnt bother me at the time but now as less wieght is free power and the fact that I found out later the body shop I took it to let the roof get wet for 2 days with no primer or protection, despite may strongly asking them to keep it inside or cover it up. So all the welds got rust and the rust has now blistered through the paint as they most not have cleaned all the rust off before painting, idiots!
So the plan now is remove the old skins and add a carbon fibre roof skin sheet, so angle grinder out and off they came;
this is where Im at now so as soon as the carbon goes on I will post pics up.
Edited by GKZ 206
stu8v
Whats the dimensions on the rad? Its looks a good setup.
Arahan
Awesome mate! Love the rear T16 style grille! No pics with a boot then I'm guessing? Would be good to see what it looked like!
Carl Chambers
its just a standard 106 GTi rad hopefully it should be good!
Carl Chambers
no not cut the boot yet wanted to get the grille right first before cutting it!
Carl Chambers
Ok the roof! why do I have these clever/stupid ideas! lol, the rear stuck down fine and left that a day to set;
end just needs trimming, but the front was a complete mare! Everyone said yeah 1mm carbon will bend fine, if not just heat it a bit! well heating didnt really work as the gel started to bubble and no it wasnt too hot! But do to the roof being curved 2 ways it was hard to bend it flat, lots of clamps and a valve spring compresser even came in handy!!!!;
We will see tomorrow how it turns out if I dare take the clamps off!
Henry Yorke
Daft as it sounds, when you refit the windscreen, I'd put in a sunroof screen rubber to reduce the chances of air / water getting under the front edge at speed
calvinhorse
looking good mr chambers
Carl Chambers
I was kind of hoping it would tuck under the windscreen rubber but after today Im not so sure that will happen!
It still got the rubber from when it had a sunroof anyway so no problem there.
mochyndu
That looks soooo sweet........keep it up :)
Ben_M
Thats looking great Carl. Keep the updates coming.
Top work as always
Carl Chambers
Well the roof is not too bad and hopefully the screen will cover up most of the wobbles along the front, had to support the middle with some carbon rods to stop it flexing too miuch;
Heater and half the dash is now gone, and engine electric cut off fitted, the heated rear screen switch will now be used for the heated front screen thats going in in case you were wondering.
A swirl pot has been fitted to stop me needing to have more the half a tank of fuel as to not get fuel starvation.
second fuel pump was needed and a race battery was also fitted to keep weight down;
tonester84
Hi really like the carbon sheet for the roof. Looks good against the Miami blue. Where a bouts is the carbon sheet from and what was used to bond it on? Thanks
Carl Chambers
Think it came from Carbon mods, and I stuck it down with stick-a-flex.
tonester84
Was thinking of doing the same to mine instead of changing the whole roof skin. Looks like a nice project u have there, what kind of money was the carbon if u don't mind me askin?
Carl Chambers
Was around £250 for a sheet but it was a large sheel and I have lots left, not enough for another roof sadly.
barry d
looking great carl.any more updates? :)
lukegroves_123
Nice looking project you've got there. I'm in the middle of a miami gti6 track conversion myself. Interesting to see the carbon sheet for the roof. Do you have any pics of the underside of the roof? Might look into the a similar idea for replacing my sunroof.
Did your car suffer much with fuel starvation before the swirl pot was fitted?
Sorry for all the questions! :blink: Just getting an idea of what mine might be like and any future issues!
Carl Chambers
the roof was cut around the strenghtening box sections that are around the roof, so with the carbon sheet on the roof look just the same as the standard roof does, apart from 3 carbon rods going across to add some strenght and stop it saging! I sprayed the underside satin black aswell so make it look better.
the sad news is that I may be breaking this car to fund going racing in my 306 BTCC, and to rob some parts to build my yellow 306 into a spare race car/track car. Sadly this 205 wont go into the race series I want to go in as the engine is not standard.
it will break my heart to do it but space and money is tight so it will have to be done, so if you are interested in any parts or the shell please let me know.
Edited by Carl Chambers
Carl Chambers
Now for sale, and all parts.
See thread here for more details.
Edited by Anthony
Carl Chambers
Well after trying to sell this car as a whole thing minus its engine, it was broken up and the cage, seats etc sold off making more money than the whole shell was for sale for!
But that left me with a nice shell doing nothing, so after getting a 5 door 1.1 205 and only doing 1 mile to work every day in my 406 V6 which was costing a bomb the idea started and the 1.1 was reshelled into the miami shell making a cheap to run work van!
Here are a few pictures!
outside is still the same still with the carbon roof but inside is totally different! 1.1 dash and seats
and rear all panelled out as a proper van;
the 1.1 power house! its not really that bad goes quite well but as said Im only a 1 mile from home to work most of which is in 30mph speed limits. 4 speed and a choke mind you takes getting used to!
now using GTi running gears and GTI-6 brakes, made mating the driveshafts interesting! luckly the 306 GTi6 shafts are hollow and the 1.1 are solid and almost the same size, so a same spacer to hold them square and they were welded together,
so it stops better than it goes with rear discs and GTi-6 front brakes!
another problem with a GTi front subframe and a TU engine was the exhaust needed to go where the gear linkage sits, so simple solution was;
front side exit exhaust lorry style, its a bit strange as all the noise comes from the front but you get used to it.
so she live on in a different life to before but I have had this car the longest, since 2003 so it would be sad to have got rid of it, now its a proper works van!
would love to get a multi van rear for it but they are hard to find now!
