kkronja 0 Posted May 11, 2011 ...well, I guess its a relay, it is certainly electric and is mounted in engine bay above/behind right (if you stand in front of a car) headlight-it is made of aluminium, raw, no paint or anodizing and cca. 20 mm diameter, has a brown plug from below,2 or 3 wires I'm not sure cause I'm not near the car (1.9 GTI motronic). cheers, kk Share this post Link to post Share on other sites
ljenkins22 0 Posted May 11, 2011 (edited) is it round? if so i would think it is the resistor for the headlights, you should have one similar on the n/s srtut topmount, i believe this one is for the cooling fan Edited May 11, 2011 by ljenkins22 Share this post Link to post Share on other sites
kkronja 0 Posted May 11, 2011 is it round? if so i would think it is the resistor for the headlights, you should have one similar on the n/s srtut topmount, i believe this one is for the cooling fan thanks for quick reply! yes, very round...well, today I took a look under a bonnet after 30km long drive, and the thing was sizzling hot, actually your answer got me puzzled,as my lights were not on...what could it be now? kk Share this post Link to post Share on other sites
ljenkins22 0 Posted May 11, 2011 resistors wiill get hot when in use, i would prob be checking the wirering going to it make sure its all clean and tidy, are you having any other issues in relation to the hot resistor? Share this post Link to post Share on other sites
smithy 1 Posted May 11, 2011 It will be the resistor for cooling fan half speed,normally clipped to top of rad on right hand side if memory serves me correctly.no longer fitted to mine as single speed only. I think the dim/dip resistor is behind headlamp and not visible when headlamp is in place. Share this post Link to post Share on other sites
