TaffyTim 6 Posted May 5, 2011 When filling the car up it likes to try and chuck half of its fuel back out of the 'in' hole. is there a breather to clean to prevent this or some other method? Share this post Link to post Share on other sites
Masekwm 2 Posted May 5, 2011 I think they all do it. The 3 I've owned have done it. Share this post Link to post Share on other sites
Anthony 1,003 Posted May 5, 2011 It's certainly not "normal" for it to spit fuel back at you, atleast not in my experience. Assuming that you suffer the issue at multiple fuel stations and pumps, I'd drop the fuel tank off the car (make sure it's low on fuel first!), check that there's no obstructions in the fill pipe and check that both of the breather pipes are clear and aren't kinked. Also, make sure that you put the nozzle in all the way and that it's pointing roughly down the filler pipe. Share this post Link to post Share on other sites
TaffyTim 6 Posted May 5, 2011 Its done it for years, worse after its been driven hard or when very low on fuel. where are the breathers? Can I access them without dropping the tank out? Share this post Link to post Share on other sites
Anthony 1,003 Posted May 5, 2011 Breathers run from the top of the tank (so you can't get to them without partly dropping the tank), through an opening behind the rear quarter, and then up and along the top of the wheelarch with the main filler pipe. There's another breather that runs to the rear of the wheelarch near the bumper mount, but as far as I'm aware that one won't cause issues with filling up, only with excess fuel tank vapour not being able to vent. Share this post Link to post Share on other sites
allye 530 3 Cars Posted May 5, 2011 really need to drop the tank as access is a right arse, the breathers can be bit of a pain to get on as well as there isn't much spare. On my old 1.8D one of the breathers had corroded so pissed a few litres od diesel over the fourcourt before I noticed never filled it over 1/2 after that. So yer breather are usually to blame. Share this post Link to post Share on other sites
TaffyTim 6 Posted May 5, 2011 ok, thanks all. How much of a pain is it to drop the tank? Share this post Link to post Share on other sites
