maxi 36 1 Cars Posted April 25, 2011 Right, since re-shelling the original sla and using a much later K plate GTi, I have had massive problems with fuel surge. I have tried all sorts of combinations to cure this as the earlier cars dont suffer so much, early pump, extra gauze baffle, everything with no success. The next and final stage is to run a swirl pot. I have done lots of research and I think a 1.5litre item is the way to go with an 044 bosch pump, using the std pump in the tank as a lift pump. Has anyone got any experiences with swirl pots? Recommendations of manufacturers and suppliers? Look forward to some input on a subject I know very little about......... Maxi Share this post Link to post Share on other sites
brumster 135 1 Cars Posted April 25, 2011 I would steer clear of using the standard in-tank pump to fill the swirl pot; it will most likely flow too much, pressurising the swirl pot and running the top return loop back into the tank at high pressure... well, put it like this, if you DO go that route, I would ensure you get a good gauge of return pipe off the top of the swirl pot to flow it all back to the tank.... but personally I'd ditch the tank pump and just run a simple carb-type Facet pump to fill the swirl pot. Share this post Link to post Share on other sites
Baz 421 Posted April 25, 2011 I'd just fit a tank and pump that match. Share this post Link to post Share on other sites
maxi 36 1 Cars Posted April 27, 2011 I'd just fit a tank and pump that match. I did that and it surged. Maxi Share this post Link to post Share on other sites
stu8v 68 1 Cars Posted April 27, 2011 I used a similar setup in my old Impreza with no issues. 1.5l-2tr swirlpot £25 Bosch 044 copy external pump £65 Std walbro 255 as a lift pump Share this post Link to post Share on other sites
Alastairh 47 Posted April 27, 2011 simple carb-type Facet pump to fill the swirl pot. Going back a few years, a mate had one of these in a 205 rallye with a 106 GTi lump. Aren't these really noisy? Or was it a one off? Ok on a rally car, but for a road car, it would do my nut in! Al Share this post Link to post Share on other sites
brumster 135 1 Cars Posted April 27, 2011 They can be if you don't mount them on rubbers, yes! Share this post Link to post Share on other sites
stu8v 68 1 Cars Posted April 27, 2011 (edited) I dont think it would be wrong to state my old setup was stupid loud! Edited April 27, 2011 by stu8v Share this post Link to post Share on other sites
maxi 36 1 Cars Posted May 1, 2011 So the general concensus is to ditch the std pump in the tank as a lift pump? Maxi Share this post Link to post Share on other sites
stu8v 68 1 Cars Posted May 1, 2011 I would keep it, if you have issues change it. Nothing ventured............ Share this post Link to post Share on other sites
darrellspeed 1 Posted February 8, 2012 Hi Maxi, how did you get on with fitting a swirl pot, which pumps did you use in the end? as you might have guessed, thats next on my agenda. Cheers Share this post Link to post Share on other sites
