Jake_GTI
Airbox Mounting Bracket
Jake_GTI
Seeing as these are virtually non existent anymore I am thinking if making my own!
I have heard that people have done this before a I want to revert back to the original from my current k&n,
Has anyone on here made thier own or know of anyone that has? I need to know things like measurements and the shape of the original etc! Even better how you did it?
If it's poss could you get some pics up so I have a start at least?
Cheers guys :)
Jake
Edited by Anthony
Fixed title
omega
whats a moondog bracket ?
smithy
by moondog bracket do you mean the bracket that bolts to exhaust manifold and cylinder head that the air box then fits to?
if so i have same problem with mine i have just used an L shape bracket from head to one of the studs on airbox for now until i can source a proper one,seems to be holding it secure at present.
Jake_GTI
Aha brilliant! Sorry it's meant to say mounting bracket! I'm on my iPhone so it's probably predictive txt going wrong :-/
What size is the bracket you are using? If it does the job then it sounds good!
jord294
i've got 3 of them o/e brackets available
just need a bit of paint :)
Jake_GTI
How much you want for one?? It's the final piece to the car (hopefully) :-D
Henry Yorke
When would you ever use Moondog in a text message?! http://en.wikipedia.org/wiki/Moondog
smithy
I would also have one of them off you if they are going spare,might aswell go standard if possible.
How much do you want for one?
omega
i thought it was a technical term that i wasnt aware of B):D
TT205
I think the moondog bracket is the one just above the wildcat bracket that traps the mousepipe with a jubillee clip :(
The mousepipe is the one that gets the cheesy mayo stuff in it B)
