RGT100
Help Arb Stuck
jord294
if you get the rear beam refreshed, you'll notice a great difference
i recently rebuilt my beam using 21mm torsion bars, new bearings, seals, new mounts and new shockers. i did lower it slightly aswell
the car feels about 10ft wide at the back :lol:
definately more planted than standard guise :huh:
RGT100
Whats the size of the slide hammers you lot use as my 5Lb one not doing a lot of anything i put a bit of heat on but the axle just laughing at me saying that all you Got
Also with gti spec Axle would i need GTi/ Dturbo Front springs?
Edited by RGT100
jord294
i've never used a slide hammer on the beams i do :lol:
RGT100
How do you Get them out special method?
Edited by RGT100
RGT100
These are the outer bearing external sizes Nick (Wurzel) sent me;
According to the vernier calipers:
Width 21.87mm (0.861 ins)
Diameter 53.17mm (2.093 ins)
Radius arm shaft is 47mm (1.85 ins).
QUOTE FROM A POST FROM A SEARCH
Got me bearing kits today from pug
£38.40 for 2 kits
My bearing
Width 19mm
Diameter 53.17mm
and it has 45 rollers
Why is it 2mm Narrower?
Make KOVO or KOYO and TORINGTON
Inner Bearing
Width 21.9mm
Diameter 49.8( I assume there is a recess for the larger outer bearing to fit in to?)
30 Rollers
Make INAx2
Also Should i worry about the inner as i read a thread about poor quality bearing cant find it but i think these were in it
Edited by RGT100
jord294
originally the outer bearings were nearly 22mm, but the 306 bearing kit came with the near 20mm outer bearings. i don't understand why :huh:
i've just made a bulk order of parts for rebuilding beams and the outer bearings are now the 20mm as in the 306 kits
all you need to do is centralise the narrower outer bearing in the end of the tube
at least they still have the full amount of needle rollers. as last year, there was an issue
Yup, the low-quality outer bearings that cause premature wear/failure only have 30 needles, rather than 45 like the originals.
RGT100
i have the low quality inner bearing 30 roller instead of the 35 will that be sufficient or am i best of sourcing a 35 roller bearing if so where can i get them from as peugeot don't do them any more
Also why is my inner bearing got a smaller diameter than the outer?
Edited by RGT100
The inner bearing has a much reduced loading compared to the outer one, and a 30 needle bearing will be fine there.
The inner bearing is always smaller diameter than the outer - that's how Peugeot designed the beams.
RGT100
hi guys
can someone just confirm this for me
5172.24 Is this the round black rubber that sits round the arb plate to stop the ARB rattling looks a bit like a half use roll of insulation tape?
and
5174.03 is this the seal that seals the arb and also is this the same as the 306 as when i was searching it was said it was different?
RGT100
How on earth are you ment to get the bearings out?
I've got the one outer bearing out but scored it a bit so going to have to clean it up a bit
Just thought i would ask you guys as im seem to bend the rim every time i try to lever it out
RGT100
Got them out wacked them out with a scaffolding bar
5172.24 Is this the round black rubber that sits round the arb plate to stop the ARB rattling looks a bit like a half used roll of insulation tape?
and
RGT100
hi guys got it all done just stuck on 1 thing clearence between crosmember seal and trailing arm (not arb)
there are 2 guides one says 0.5mm and the other 0.05mm wich is it?
arb clearence is 1mm
Also i have a plastic ring come with the kit do i fit it aswell of do you guys leave it out?
Edited by RGT100
RGT100
Right guys i have got the axle back together every things fine im going on a breakers yard hunt for parts tommorow in the list im after a 24mm Arb
so Far i know there in the XSi/GTI/Hdi Dturbo
Are the 24mm ARB in the xud Dturbo's eg 1993-99?
If so it would be a lot easier to find as there are many of them in the breakers round here
The axle that came of my car is completley shot there where no bearings left and it ground out the tube like an egg oval
Are the trailing arms worth any thing guys or shall i give them to the scrap metal man?
RossD
The earlier DTurbos didn't have the 24mm rear ARB, at least mine didn't when I had one several years ago! You can also be looking on the Xsara VTS's.
yup, you wont find a 24mm arb on an XUD, only the DW10 DTurbo and the S16/XSI/GTI6/Rallye.
phase 1 Xsara VTS, not phase 2 which is listed as a 23mm arb.
RGT100
hi guys are the trailing arms worth anything there HDI disc hub with bearing & ABS the shafts would have to be pressed out as they are knackerd
Some early Phase 2 VTS's also have a 24mm ARB (such as the 51 plate one I've just done for a work colleague)
And did you mean DTurbo as in trim level, as most HDi's don't have a 24mm ARB - seems to be 20 or 22mm from what I've seen?
Alastairh
22mm Shuttle.
yup DTurbo HDI is full sport spec as opposed to the older XUD9TE DTurbo which is XS spec.
They're petty much all gti6 bar front brakes springs gearbox and engine, all half leather auto wipers aircon etc.
