Jake_GTI
Engine Swap (help)
Jake_GTI
hi, my engine is dead unfortunately, think is is beyond repair, it's not a problem though as i have been offered a replacement engine with lower miles and in good running order from a phase 1.5 which is getting a gti6 conversion!
my problem is i dont have the time or knowledge to remove my dead engine and install the replacement!
does anyone on here live in west sussex and would be willing to do the job for me for beer tokens? the car also needs a few other bits replacing (driveshafts, anti roll links, track rod ends and front brake hoses) all of which i have at home ready to go on!
once the old engine is out i will be breaking it and selling anything thats not knackered probs via ebay as i'm not allowed to sell on here yet :)
cheers for looking,
jake
kyepan
That would be a fair amount of beer tokens... realistically you probably should pay someone to do it properly or find the time and learn yourself.
especially when you factor in the other service items that need doing.
Miles is highly recommended and not a million miles away from you.
J
Jake_GTI
J
i cant get the car to him though :) its completely dead!
i know people who will do the work for £20 an hour labour but theyre tight for time so i would have to wait a while and need my car back :P
Jake_GTI
and also i work as a chef so have zero time to learn to d the work which sux cos i'd love to learn how!
i have all the parts and an engine crane which is a start though i suppose lol
Edited by Jake_GTI
omega
can you ask the guy you getting the engine from to fit it?
i think you will be lucky to get someone to come round and do it unless you have a engine crane.
go on have a go you will get plenty of help off here.use the search on here and get a haynes manual and you will crack it.
ah must type faster
Edited by omega
Jake_GTI
ah must type faster
i got a crane :)
Jake_GTI
plus the guy is in brighton and is a student so i doubt he'd have time, plus i cant move my car atm, i am probably gunna have to tow it somewhere to get it done :)
allye
Its always good to say give it ago and its a good way to learn. However unless you have some one with the knowledge or the correct tools (of which there are plenty for an engine swap!) its better not to bodge! Pay some one to do it correctly (or help you) and cycle for now :o
Daviewonder
Jobs like this sound quite straight forward, but you need to remember the car's 20+ years old and chances are as you go along you'll uncover loads of bits that need replacing like broken wiring, broken connecters, perished hoses, worn clutch, seized nuts and bolts. Plus I would change the timing belt and tensioner and water pump while the engines out, so before you know it it's turned into quite a big job, not really something someone wants to do for a few beers :o
Jake_GTI
the belts and pump etc on the new engine are all new with recipts, and it comes with a pretty much new silicone hose kit aswell! and i put a new clutch in my gearbox in jan last year so i know thats all good!
harryskid
I wish my conversion had cost just a few beer tokens. Also if i had paid £20 and hour i'd be quids in! :ph34r:
Matt205
If you can change a clutch, then you should be ok to undertake the engine swap if you take your time and search/post here when uncertain. These undertakings always take longer and more cash than you originally anticipate. Why don't you consider buying a cheap banger to keep you on the road and therefore provide you with time to approach the engine swap without unreasonable pressure.
Jake_GTI
i didnt change the clutch myself, im no mechanic so i paid someone else to do it for me! how much roughly would it cost me to get the engine put in along with the other work that needs doing roughly?
NeilGTi85
To switch the engine like for like would be around £500 + other parts if they break etc. as i was in the same boat and asked Miles....
Neil
monkee87
Have you decided what to do yet? You could swap an engine in a day if everything goes to plan.
I could maybe help you do it. You're not too far from me.. Only problem is I don't drink! :lol:
....and at the same time, you could swap the engine in a week or more depending on how much stuff is broken/knackered/seized when doing the swap.
unariciflocos
I'm stuck in Wales over the weekend with nothing to do, but unfortunately I'm too far away.
I've swapped engines in one day and it should be straightforward if you have a crane, but with old cars there's always that one bolt that will give you a hard time and ruins all plans.
large
What part of Wales.
matty_gti
I'm always in Horsham and the Mrs works in Pulborough so I could help with a swap if you like, done swaps in a day before (when it all goes smoothly!) or if you could get the car to me in Surrey I could do the work at my house.:o
Edited by matty_gti
Jake_GTI
@monkee87 & matty gti,
any help would be appreciated! the engine and the car will be in pulborough until it's up and running, i cant see myself doing it over the course of a day tbh but i dont mind taking time over it to make sure i get it right! and like i say any time will be paid for as i dont expect people to work for free, i certainly wouldn't cook for free!(i'm a chef btw)
monkee87
Do you have a complete engine btw? Didn't you say you've got a 1.9 to go in? Do you have all the ancillaries? AFM etc etc.. Is the gearbox still on the new engine?
If the engine is complete it should be very straight forward. :P I'll let you know if I can deffo help, got quite alot of free time ATM! :o
matty_gti
Have you got any/all the tools at your house where the car is?. If so I could make a start this weekend :P
Jake_GTI
unfortunately my tool kit consists of pretty much only mountain bike tools and screwdrivers! i am able to get hold of tools though!
the engine is a 1.6 and yes it has all ancillaries, and the gearbox, i was however considering keeping my box as it's the original ph1 (be3?) box and it has a new clutch in!
matty_gti
It would be a BE1 and that age and takes 5mins to swap gearboxes with the engine out of the car.
Jake_GTI
Sweet, well that's good news! Unfortunately being a chef I have to work weekends apart from Sunday nights which could pose a problem :-/ I have some time off in early feb though!!
