PaulJLLD
Renault Megane
PaulJLLD
hi,
Anyone done a timing belt on a 06 1.9 diesel renault megane? From what i remember most if not all the 16v petrols dont have a key way on the timing belt crankpully, Was wondering if the new diesels are the same?
Thanks paul
Edited by PaulJLLD
hcmini1989
hi,
Anyone dont a timing belt in a 06 1.9 diesel renault megane? From what i remember most if not all the 16v petrols dont have a key way on the timing belt crankpully, Was wondering if the new diesels are the same?
Thanks paul
No they dont mate .Best way is to take the flywheel cover plate off underneith and mark the flywheel up saves buying all the timing pins ,Just use a ruler and some tipex or a scribe
PaulJLLD
Spot on thought someone would know on here :lol:.Thought as much. from what iv seen the locking kits ant cheap for them either. Dont realy want to have to buy a locking kit for one as i never work on renaults. Thank god.
hcmini1989
A few years ago when i started my aperenticeship i had one of these in it was a petrol one and was goin like a bull in a china shop on it and buzzed the bottom pulley off ,So my old boss had to buy the kits and think it was something stupid like £70 just for the bottom pin .Waste of money unless the belt snaps then youll need one .Otherwise just do the above with the tipex
PaulJLLD
Ooch, I only asked cause when i work at a garage before i went on by own i remember one of the lads doing a 1.4 16v and didnt spot the was no key way in the crank, put the belt on and didnt turn the engine over and BANG 16 bent valve for what i remember.
Mikey S
just a note, not all the 1.9 dci's have a keyway on the bottom pulley. ive certainly seen lagunas like this but ive not done a 1.9 dci in a megane, only a 1.5.
mike
hcmini1989
mike
Abit odd mate as id have thought that they were the same .Ive done a few now and they havnt but i wouldnt take the chance and not mark the flywheel just in case.And tbh ive never payed to much attention to the ones i have done after i knackerd the first one up i always marked the flywheel
Mikey S
believe it or not i did a laguna dci with a keyway on the crank, i thought it was odd as well. i always pin these, just like zetecs as they dont need to be far out to bend valves.
hcmini1989
I wasnt disbeleiving you mate infact the opposite usual french crap always changing ,And a few of the ones ive done might have had keyways but i never noticed and just marked up the flywheel so never botherd to check it,The only bonus to these is makes setting the tension on the belt easier
fatony1
*shudder* Renault cam belts, who's got a 1.6 VVT Dephaser pulley story to tell? :ph34r:
