djinuk 2 Posted January 18, 2011 hi there people i have just got a peugeot 205 with a mi 16 engine in with a 1.6 gear box could any 1 tell me were the reverse light switch is please Share this post Link to post Share on other sites
large 33 Posted January 18, 2011 (edited) Is the box a be1 or be3, Iirc it is normaly on the front around by the clutch arm. I think it should have a blue 2 pin plug going to it. Edited January 18, 2011 by large Share this post Link to post Share on other sites
djinuk 2 Posted January 19, 2011 well the car was a auto now manual its a 1.6 box no idea what type tho Share this post Link to post Share on other sites
Anthony 1,003 Posted January 19, 2011 I think it should have a blue 2 pin plug going to it. It's a white 2-pin plug for the reverse switch. Blue 2-pin is for the ECU temp sender. BE1 and BE3 reverse switches are different - BE1 is reverse next to 1st, BE3 is reverse below 5th. Share this post Link to post Share on other sites
djinuk 2 Posted January 19, 2011 It's a white 2-pin plug for the reverse switch. Blue 2-pin is for the ECU temp sender. BE1 and BE3 reverse switches are different - BE1 is reverse next to 1st, BE3 is reverse below 5th. so i have to wires hanging down in the middle of the car as it was a auto so do i connect these to the white 2 pin plug or were do i connect them thanx? Share this post Link to post Share on other sites
Anthony 1,003 Posted January 19, 2011 Touch the two wires together - reverse light should come on if they're the right two wires. From memory, they're purple and brown on manual cars. Assume they are and it does, and the reverse light comes on, then simply put one wire to each pin on the reverse switch. Share this post Link to post Share on other sites
djinuk 2 Posted January 19, 2011 ok thank you ill have a look at it wensday and let you no thanx for your help Share this post Link to post Share on other sites
ade 4wd 11 Posted January 19, 2011 If it was an auto box the reverse switch was at the front of the gearbox and had 4 wires going to it as it was also the starter inhibitor switch. Have a look by the screen washer bottle for the loom, you should see 4 wires going nowhere. Find out which 2 are for the reverse light and extend them to the switch on top of the BE gearbox. The 2 wires you can see in the middle of the car might be for the gear selecter ilumination used only on auto models. Share this post Link to post Share on other sites
djinuk 2 Posted January 28, 2011 had another look at this the wires under the when joined toghter dont do any thing had a look by the washer bottle couldnt see the for wires?? all help gratefully received Share this post Link to post Share on other sites
