shalmaneser
Indicator Not Working?
shalmaneser
Very mysterious, this packed up a while ago and hasn't started working since. Bulb is fine, connector seems fine, does anyone know of any wiring weakspots?
All the other indicators/lights/etc seem fine, but this one stubbornly refuses to work!!!!
Usually just a corroded connector that's making a lousy contact, either near the indicator or on the earth point near the headlight.
If it doubt, put the hazards on and then wiggle/disconnect/connect the connectors until you find what's causing the issue, and then rectify it properly.
