Jeffers_S13 0 Posted December 31, 2010 Anyone know for sure if the main hoop of an OMP cage will fit in a Mondeo estate ?? Thanks James Share this post Link to post Share on other sites
welshpug 1,737 Posted December 31, 2010 depends if the vehicle it's intended for has a larger interior than a Mondeo or not Share this post Link to post Share on other sites
brumster 135 1 Cars Posted December 31, 2010 Recently tried to get a cage main hoop (with the rear legs too) for a 205 into a new-age Mondeo Estate - answer was "no chance". It wasn't an OMP cage, though, so not sure if the rear legs were significantly different that it may be a different story for you.... Share this post Link to post Share on other sites
BusEngineer 7 Posted December 31, 2010 Mine was delivered out of the back of a mk5 Escort hatchback, 10 point bolt in Share this post Link to post Share on other sites
Miles 331 1 Cars Posted January 1, 2011 It should do as it's not a great angle, I got a 306 SD cage in my 406 just and thats huge in comparrison Share this post Link to post Share on other sites
Alan_M 66 1 Cars Posted January 1, 2011 I managed to squeeze a 10pt OMP cage into the 205.....hardest part is the fixed rear and main hoop. Share this post Link to post Share on other sites
Cameron 16 Posted January 1, 2011 I squeezed my SD weld-in cage in the back of my Mondeo estate, so yes. Share this post Link to post Share on other sites
boombang 2 Posted January 2, 2011 Approx measurements are 160 x 100 x 70. Thats the width, height and then depth (from the B piller legs to rear stays). Will need a touch more than that to allow for the poke outs top of B pillar, bit having just wrenched one out of a 205, am actually now convinced it will go in almost anything. About to put it into a Vauxhall Corsa C to get it over to mine, that'll be the true test. In fact it's worse than that, as I've got to try and get my mountain bike in with it... Share this post Link to post Share on other sites
Jeffers_S13 0 Posted January 5, 2011 It fitted with a little room to spare Thanks to boombang for easy deal and good communications ! Share this post Link to post Share on other sites
boombang 2 Posted January 5, 2011 Only a little room mind! Thanks for the thanks - you made it all a lot easier getting it collected, just wish everyone was so simple to deal with. Share this post Link to post Share on other sites
