justinv 4 1 Cars Posted December 29, 2010 Small question, Got my phase 1.5 coil removed and forgot to tag where the wires go anyone can help ? Share this post Link to post Share on other sites
smithy 1 Posted December 30, 2010 Small question, Got my phase 1.5 coil removed and forgot to tag where the wires go anyone can help ? i take it you have wing mounted coil? on my phase 1.5 there are 2 thick red wires on coil + it has got a yellow wire and green screened wire in 1 spade and then another green screen and grey wire in another spade both connected to coil - from memory the reds are from iginition switch and then to ign amp the coil- wires are from/to dizzy,ign amp,tachy relay and rev counter but a search will reveal more details should you need it. Share this post Link to post Share on other sites
justinv 4 1 Cars Posted December 30, 2010 Hi, thanks This should be enough, but will get back here if any problems arise. The screened green wire does only the green wire go to the +ve ? or even the screen ? Share this post Link to post Share on other sites
smithy 1 Posted December 30, 2010 Hi, thanks This should be enough, but will get back here if any problems arise. The screened green wire does only the green wire go to the +ve ? or even the screen ? mine are a screened thick wire with a smaller green wire coming out,it then goes to the - the screen part does not go anywhere it has just got a insulating sleeve over it. it is only the red wires that go to + all others are on the - post. can get a piccy tomorrow if you want? if so pm me you email addy and i will send tom afternoon Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted January 2, 2011 http://forum.205gtidrivers.com/index.php?s...t&p=1000195 Graham. Share this post Link to post Share on other sites
