miamigtimark
Radiator Electrical Connection. Confirmation Needed
miamigtimark
Tried search but brought nothing.
Just need confirmation that wires from radiator (one black / one red) plug into the shunt box??? And which "slot"??
Cheers!!
justinv
Was going to put up this tread asremoved them by mistake and forgot from where lol !
also need to know the yellow earth connectors where they bolt on, on the chassy as forgot aswell :lol:
smithy
Cheers!!
on my phase 1.5 the slots in shunt box are all different so not possible to put plug in wrong.
as for the fans sorry cannot help because i ripped all mine off and wired it better using a relay.
miamigtimark
Guys. My apologies for dragging this one back to the top but im still struggling!!
I have viewed pretty much every related post using search function.
My initial post wasnt very clear so to clarify....
I have the fan wires (one red one black) that come from the middle of the fan assembly and a white plug (male i think) at the end.
When attached directly to the battery the fan kicks in.
I cannot find where this white connector should plug into on my loom.
Car is a 1600 phase 2 converted to gti6.
T.I.A
murtaghp
I'll have a look at mine tomorrow as it's in pieces just now.
I'm sure it plugs into a white male connector on the same piece of loom that the thermal switch plug sits.
I'll try to get some pictures tomorrow if I remember.
miamigtimark
That would be great. Cheers!
im pretty sure thats where it should go . BUT cant see the connector.
ade 4wd
Locate the rad fan switch on the rad and follow those 3 wires, there should be a connector for the fan to connect to. The fan does not connect directly into the shunt box.
murtaghp
Right I had a look at mine today, the fan connects into a white two blade connector that's on the same loom as the thermoswitch and the fan resistor.
There is also a earth connection that goes into the shunt box from the same section of loom.
That is +12V, not earth. The only earth on the shunt box are the bolts going through it.
murtaghp
Well spotted, I suppose this is the power connection that's been missing all along.
Bear in mind though that I have disconnected the main loom from the box so the one that you are interested in is to the left of the picture.
miamigtimark
Brilliant!!.
Thanks for posting the pics. Helped a lot.
Loom is back in play but still no fans. (got plenty of search material to look at for that problem though)
CHEERS!
The fan loom is a self contained loom seperate from the rest of the engine bay wiring that only runs between the shunt box, radiator temp switch, silver resistor, fans & earth block.
Graham.
