mogsman 2 Posted December 10, 2010 Hi all, the car passed its MoT earlier and had an advisory to replace one of the outboard cv boots. I went to my local motorfactors for a cone and they had a green flimsy plastic cone for £15. I didn't buy it as the bloke behind the counter said it wouldn't last, so are there any that can be recommended and are quite robust? Ian Share this post Link to post Share on other sites
welshpug 1,737 Posted December 10, 2010 I never bother with cones, just knock the joint off if its a 1.9, or remove the inboard joint if its a 1.6. Share this post Link to post Share on other sites
mogsman 2 Posted December 10, 2010 Its a 1.6 and too scared to remove the in board joint for loosing bearings, oil or whatever else might fall out. Never done this before so I thought the cone would be the easiest option. Ian Share this post Link to post Share on other sites
Ryan 99 Posted December 10, 2010 The plastic ones work well enough for the occasional job. Unless you plan on changing boots on a daily basis then it's not worth spending loads on anything better. I got one off ebay for a fiver, used it twice and it's been fine. Share this post Link to post Share on other sites
Jrod 7 Posted December 12, 2010 I cut the top off a roadside cone. Share this post Link to post Share on other sites
Miles 331 1 Cars Posted December 12, 2010 If its only a small split just use some Superglue to stick it back together, will outlast the rest of the boot Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted December 13, 2010 If you have use of a cone I've fitted the AMK stretchy boot kits on both 1.6 & 1.9 driveshafts with good results (no leaks & lasting 2 years +) & my car is mostly used on track. I have one of the "flimsy green" cones & it's worked fine various times as long as you lube it well so th boot slides over it easily. I've had it a few years & it cost less than £10 iirc. Graham. Share this post Link to post Share on other sites
Masekwm 2 Posted December 13, 2010 How do you know if a boot is a stretch boot? I have a shaftec boot but don't have a clue how to fit it Share this post Link to post Share on other sites
Ryan 99 Posted December 13, 2010 I think most aftermarket boots are usually the stretch kind. Fitting is dead easy: Share this post Link to post Share on other sites
Tom Fenton 1,650 Posted December 13, 2010 You can get stretch and non stretch boots, you will soon know as the non stretch will not stretch!! I have an air operated tool that makes it a doddle of a job, perfect for doing run of the mill hatchbacks for people in double quick time. I tend to use non stretch boots on my own cars though I have to say. Share this post Link to post Share on other sites
Alastairh 47 Posted December 13, 2010 I cut the top off a roadside cone. Genius! Share this post Link to post Share on other sites
