jeremy 71 Posted December 5, 2010 (edited) Ok I recently replaced the heater control valve on my daughter rust bucket disguised in purple paint. This does not seem to have made ablind bit of difference to the heat inside the car, varies between cold and more.... ... cold. Swapped the inlet pipes over today as thought they maybe on the wrong way round, made no difference. Could someone conform the correct way these are supposed to be mounted? I have taken there thermostat out and this appears to open and close below boiling temp. It is as if the valve is not opening or the matrix is blocked. I do not want to take the matrix out so is there an easy way to test it? Should I check anything else? Sorry for this post being a bit hap hazzard in its layout but had a few beers. Also what does the red button do hidden behind the carpet in the kick pannel (drivers side) as like a child I could not resist and push it. Edited December 5, 2010 by jeremy Share this post Link to post Share on other sites
stuart1298 7 Posted December 5, 2010 where did u buy it? i have known these to be fitted and not work from the off!! and i sell these on a daily basis Share this post Link to post Share on other sites
jeremy 71 Posted December 5, 2010 where did u buy it? i have known these to be fitted and not work from the off!! and i sell these on a daily basis My local motorist place, normally really good, but no original equipment. Share this post Link to post Share on other sites
welshpug 1,737 Posted December 5, 2010 (edited) take both pipes off and stick a hose pipe on one, that'll give an idea if its blocked or not. red button is the inertia switch, at least you know where it is now isn't it a simple butterfly in a pipe kinda valve, should be able to see if its working if so, if possible try fitting the pipes directly. Edited December 5, 2010 by welshpug Share this post Link to post Share on other sites
Tom Fenton 1,650 Posted December 5, 2010 The pattern valves are s*ite. At the moment I would be tempted to get two hose joiners and link it through, to give you some hot water to the heater in this weather. Then worry about making it work right in the summer/never* *(delete as you can be arsed) Share this post Link to post Share on other sites
stuart1298 7 Posted December 5, 2010 take it back, go buy one from ford there about 30 quid Share this post Link to post Share on other sites
Flozman 4 Posted December 5, 2010 i think that might be jumping to conclusions, are the pipes getting hot? Have you purged the system of air? Share this post Link to post Share on other sites
jeremy 71 Posted December 5, 2010 i think that might be jumping to conclusions, are the pipes getting hot? Have you purged the system of air? Well filled it up and gave the radiator top hose a good squeeze. Does this count? Also again which is the correct way round for the pipes? Also what does the interia switch do? Thanks jeremy Share this post Link to post Share on other sites
stuart1298 7 Posted December 5, 2010 i work for ECP, i refuse to sell them to any of my customers, i've fitted a few myself, and always bought em from the dealer! Share this post Link to post Share on other sites
Flozman 4 Posted December 5, 2010 Well filled it up and gave the radiator top hose a good squeeze. Does this count? Also again which is the correct way round for the pipes? Also what does the interia switch do? Thanks jeremy Leave the expansion cap off and run the engine upto temp with the heating on full wack and rev it a few times and watch for air bubbles rising out of the tank, give the radiator hoses a good sqeeze left side / right side aternating about a dozen times, which should get rid of alot of trapped air. Then replace the cap when you no longer see bubbles. Touch the radiator, is it getting warm all over? are the cooling hoses getting hot either side of the radiator? Just to establish if there is circulation, if they are hot then you can go back to the matrix. Touch the hose going into the control valve if one is hot then that the inlet and it should be on the left (I think). The only way to establish is it the the Valve is faulty is to bypass it with a couple of hose joiners available from halford gubbin section (cheap) and if you still have no hot air its the matrix blocked. If you have hot air iafter bypassing you need a new valve. Interia switch cuts fuel pump in a accident. Might be useful link - http://www.khantazi.org/Archives/Ford_Ka_H...alveRepair.html Please bear in mind my experience with this engine was in a MK4 escort! Share this post Link to post Share on other sites
