jord294 97 Posted November 14, 2010 hi guys i have a zero mileage mi16 d6c engine in my posession, and i'm contemplating selling it. but only if i have interest will i advertise it in the 'for sale' section so, as said, Zero Miles, Rebuilt to the following spec. Cast Iron Heavy duty re-bored block Engine mount kit, crank reground, new bearings shells, oil pump, timing belt kit, sump gasket set , water pump, Piston rings. Fully assembled & painted black. comes with fancy 8 branch exhaust manifold, inlet manifold and throttle body, clutch and flywheel the rear mount i'll supply will have a new group n bush fitted so, if your interested, please let me know many thanks Share this post Link to post Share on other sites
boombang 2 Posted November 14, 2010 Who rebuilt it and do you have a price in mind? Share this post Link to post Share on other sites
maturin23 10 Posted November 14, 2010 (edited) "Zero miles" is rather disingenuous - the crank, rods, pistons and block are all 'used', plus you've not even mentioned the top end. Brand new head and valve gear? It has to be described as 'zero miles since partial recondition'. Not very helpful but I would have thought you'd have to offer a warranty to get decent money. I'd value a rebuit engine with 2000 miles under its rings significantly higher than one that's not been run at all. Edited November 14, 2010 by maturin23 Share this post Link to post Share on other sites
Anthony 1,003 Posted November 14, 2010 i have a zero mileage mi16 d6c engine in my posession Cast Iron Heavy duty re-bored block I might be missing something here, but if it's an iron block, then it isn't a D6C engine - D6C is an alloy block XU9J4 non-CAT 1.9 Mi16 Share this post Link to post Share on other sites
jord294 97 Posted November 14, 2010 (edited) sorry for my unclear description. but what i have is similar to what is listed here http://www.hiflowheads.co.uk/forsale/engines.php if you speak to andy. he will give you the exact spec. my last conversation with him, he assured me it is a d6c engine i wouldn't be asking anywhere near what they are, and remember it comes with manifolds etc cheers Edited November 14, 2010 by jord294 Share this post Link to post Share on other sites
hcmini1989 16 Posted November 14, 2010 sorry for my unclear description. but what i have is similar to what is listed here http://www.hiflowheads.co.uk/forsale/engines.php if you speak to andy. he will give you the exact spec. my last conversation with him, he assured me it is a d6c engine i wouldn't be asking anywhere near what they are, and remember it comes with manifolds etc cheers Any pics ?.Wasnt this one of those low comp engines (brand new jobby) .But rebuilt into hi comp spec.Ebay it these motors fetch stupid money even when they`ve done 100k plus . Share this post Link to post Share on other sites
Miles 331 1 Cars Posted November 14, 2010 (edited) I'd look at the block to see if it's Alloy or Iron and this will clear up allot of things, If it's a Iron block then its not a D6C And all blocks are std Iron, non are Heavy duty I'm afraid Edited November 14, 2010 by Miles Share this post Link to post Share on other sites
jord294 97 Posted November 14, 2010 definatly an alloy block will post pics up as soon as i get some charge in the camera Share this post Link to post Share on other sites
Miles 331 1 Cars Posted November 14, 2010 Thats a relief, Makes it worth allot more Share this post Link to post Share on other sites
jord294 97 Posted November 14, 2010 definatly an alloy block but unfortuneatly can't get a decent pic of the plate anyway, here is a couple of pics Share this post Link to post Share on other sites
jord294 97 Posted November 16, 2010 (edited) UPDATE having spoke to the original builder of this engine, i can confirm that the engine was fully stripped, and was chemically cleaned before rebuild so to make things more clearer. this engine has done zero miles since partial recondition the head was also pressure tested, with the valves re-ground and new stem seals fitted i've been told that the manifold is o/e (i thought they were cast ) a lot of money spent on new parts so if you are genuinely interested, please let me know, then i will advertise properly in the appropriate section thanks Edited November 16, 2010 by jord294 Share this post Link to post Share on other sites
boombang 2 Posted November 16, 2010 Still wondering who rebuilt it? Manifold is definately OE btw. Share this post Link to post Share on other sites
jord294 97 Posted November 16, 2010 Still wondering who rebuilt it? Manifold is definately OE btw. as i mentioned in previous post. it was built by http://www.hiflowheads.co.uk/ Share this post Link to post Share on other sites
boombang 2 Posted November 16, 2010 Not being picky, but you stated similar to the spec on their site rather than actually built by them - thanks for clarifying though. I've had dealings in past with HFH so I'm no longer interested. Share this post Link to post Share on other sites
