Peetypug 5 Posted November 3, 2010 Went for my first drive in my 6engined 205 this morning Went very well andwas over the moon, till I got home and it spat its coolant out Its using BBM hoses that have the T piece in, my last one didn't have this, it had what was a pretty standard hose setup. I bled the system as per Haynes manual as well as possible with this hose setup My last one I had a 6 header tank cap on but I have the standard 1.6 on this Could this be the problem? Anybody else running standard header tank caps? What other caps are the same as the 6 ones? The engine is a good one and I know the HG isn't on its way! Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted November 3, 2010 Garry's topics below might help find a fix; http://forum.205gtidrivers.com/index.php?showtopic=94051 http://forum.205gtidrivers.com/index.php?showtopic=97734 It might simply be worth refilling it & running the engine up to temp with the cap off though to see if its storing air pockets anywhere. Graham. Share this post Link to post Share on other sites
welshpug 1,737 Posted November 3, 2010 with the cooling systems most 405's 406's and 306's run at 1.4 bar, standard 205 runs at 1 bar IIRC,. Share this post Link to post Share on other sites
de Noir 0 Posted November 4, 2010 Pete, my Mi kept spitting coolant out because I've lost the 'slow' fan speed... When 'fast' kicked in it was too late! Chec your switch or fan module if you're running 306 fan electrics. Share this post Link to post Share on other sites
Miles 331 1 Cars Posted November 4, 2010 Should be fine with the std 205 cap, To be honest I've had more problems with the late caps due to not fitting well. A 205 I have had in for wiring ran sweat as but the header tank was like a fountain when I added the water, the water came out that quick due to a massive blow between 2 & 3 to the water jacket. Share this post Link to post Share on other sites
Peetypug 5 Posted November 4, 2010 It was fine in marksorrento205s car last week, I've probably just not bled it properly. Share this post Link to post Share on other sites
Peetypug 5 Posted November 4, 2010 Just been out and bled it again Took the top heater hose off and it had an air block in the matrix Anyway been for another spin and the heaters get nice and warm, but there is still a little trickle coming from the cap I'm hoping its just that its a bit over full So when the wife gets home I will borrow the one off the 306 and are what happens Share this post Link to post Share on other sites
