smithy 1 Posted October 25, 2010 after some info on throttle cables. i have got a 1.6 gti that has had a 1.9 fitted i it bought a couple of months back as non runner and am in the process of rebuilding it. tried putting the throttle cable back on today it is routed past fuel filter over top of engine mount and down the back of inlet manifold to throttle body so that looks ok.the problem i have is the outer cable will only just reach the plastic adjuster in throttle body bracket the inner bowden cable can be fitted but it is too short and will not allow throttle to close fully. i have a spare cable that came with car but that is the same length as what is fitted,ordinarily i would just buy a new cable but i dont want to get a new one only to find it is the same length as what i have already got. are the 1.6 cables shorther than the 1.9 cables or is it simply i have just routed it incorrectly? Share this post Link to post Share on other sites
jackherer 543 Posted October 25, 2010 The old one should fit but a new one definitely will, they are supplied longer than needed to fit different models then cut down to length. Share this post Link to post Share on other sites
smithy 1 Posted October 26, 2010 The old one should fit but a new one definitely will, they are supplied longer than needed to fit different models then cut down to length. Thanks will get a new one from pug. Share this post Link to post Share on other sites
