parry
Dash2 With Dl1 Setup
parry
Hi guys,
Just installed a Dash2 with a DL1 and am wondering if anybody has the formula for the standard pug sensors. I also see there is 2 sensor on the thermo housing, how can I tell which one is the switch and which is the temp sensor.
Also while I am here, I have found the fuel level sender wire, but does this measure voltage or resistance?
Any help would be apreciated.
Regards,
Parry
Sydney AUS
[L'e$kro]
Hello Parry
The temperature switch is open when cold, with a multimeter you shouldn't find any continuity
The coolant sensor is a resistance that changes according to temp. With an ohm-meter you will be able to mesure it's resistance
Hope this helps
Nicolas
IIRC the smaller of the two sensors is the temp sender & the larger the switch.
Graham.
parry
Graham.
Thanks, yep that works a treat. Also the larger oil sensor is the pressure sensor on the front of the block.
All looking good and easy to configure using the DL1 software.
