ben25
[trackday_prep] 205gti-6 Track Ready !
SurGie
I love carbs also, i have a set a few years ago and now im looking at fitting some throttle bodies.
Great work there Ben, your black 205 did not look that bad from the picture, was the chassis bent or something ?
ben25
Yes there is chassis damage and lots of rust. I have prefer to start a new project from a clean shell without any rust and welded. I've sandblasted all the undernearth and after I've treated it for rust.
Now the car is running, I've made 4 wheels alignement ! The car run fine but I need to adjust the advance and carbs synchronisation.
Few pics :
DRTDVL
Nice car man....
Here i was thinking my car was the only one with an e30 lip on it.
ben25
Thanks, maybe your 205 is the one in UK lol ; Me I'm sure that I'm the one in France. :)
DRTDVL
Haha i know i'm the only one in New Zealand although i've given a spare lip to a friend to make one for his car...
Love the green / white combo.
ben25
Some pics of my first return on track with the car, after 10 months of rebuilding, it was this weekend at Dijon-Prenois (FR) :
Everything was ok with the car, on a straigh lane, i follow an exige 190hp so I'm happy with my engine summer tune. :rolleyes:
I'm not so far from the clio 2 et 3 cup so it's good news for chassis/engine on track.
Total specs of the car :
General :
205 Gti ph1 year 89
110000miles black RHD convert to White LHD now
Shell :
Crash on january 2011, shell swap during this summer
New shell buy without any rust : shell completely sandblasted, welded, alla undernearth treated against rust, suspension straightening plate welded
Roll Cage Ø50mm
Châssis :
Front :
Coilovers Bilstein grA 1600
Compbrake excentric top mount
OEM front hub bored to Ø54mm (to match grA coilovers)
Subframe welded
Combrake rose jointed wishbones
gti16 front ARB
Short GrA front drop link (mounted between hub and ARB)
Rear :
309 gti16 rear axle
Complete Steel bush
PTS asphalte rear suspension
Brake :
Full stainless pipe with limiter
23.8mm master cylinder , mounted without servo
brembo 406 calipers
RC6 pads
Xantia disks 288mm
OEM rear caliper with EBC yellow pads
Engine :
XU10J4RS : 80 000 km
new rod bearing , compression tested : 10.4 , 10.3 , 10.3, 10.5 (in bar)
Cams Newman PH2
Race Oil pump
Twin Dellorto 45 DHLA carbs
Ventury : 38
idle jet : 55
main jet : 152
emulsion : 7772.5
air corrector : 200
new sealsl kit
News 205gti ignition, new sparks
Suppresion of thermostat and oil cooler
Gearbox :
1.6 GTi
Quaife diff with new diff bearing
Interior :
Light !
Shortshift Compbrake
Batery relocation on boot
3 gagues : P oil, T water, T water
knock Sensor
Alfano race chrono
Exterior :
Original look
Automatic fiber front bonnet with carbon sticker
Perspex windows (except front)
BMW e30 ph1 front lip
Tune :
Carbs synchronisation with carbtune
Advance tune with my knock sensor
Colortune for "AFR" verification
Laser alignement :
-3° camber
-0,22° toe in
2,25° caster
The cas is now out the road for winter and will go back on track next year.
Winter modification :
I plan to increase the rear camber by mounting 207 rear hubs with clio cup camber shims. (nice upgrade found on a french forum)
Do you have any more information or a link to this?
The stub axle is attached to a plate that bolts on rather than being pressed into the trailing arm as the 207 torsion beam is made from plate steel, 207 hubs are similar to later 307 ones and are integral to the disc, though the bearing is replaceable.
cybernck
You've done an outstanding job with the rebuild.
Good luck with it :).
Fernando Martins
hi, can you report to us how the Cams Newman PH2 work in trackday?
chipstick
Any updates on this?
ben25
So I need to speek about my experience with newmans ph2, I mount it, and after that, I'm going on RR to see what figure it produce.
I was suprised by the score : 154hp at flywheel (I don't know how much hp I have before the ph2). So since I've tried to tune my carbs but without any change, so I choose the Megajolt (electronic ignition) solution to tune my ignition, but I have problem with the megajolt and finaly the car don''t start and I don't know why.
So now, I'm a bit fed'up with my carbs setup so I'm tempted to buy bodies and standalone ECU for my setup or buy an other completely standard XU10j4RS with loom and ecu to have a reliable 165hp with an ECU.
I spend lot of my time and money on the car and now I'm a bit disgusted cause It don't work as it should, and my motivation go down day after day...
SurGie
These things are there to test us Ben, try not to let it get to you.
If you did go the throttle bodies route, you could get it tuned up the next time you come to the UK, there are quite a few around.
did you set the lift @ TDC figures for the PH2's? I haven't had my engine on a Dyno or RR but it is quicker than with the original camshafts.
