Henry 1.9GTi 38 Posted August 24, 2010 I have just removed my fuel pump prior to ordering a new one and was expecting to find a P2 pump as the car is a 1990. This is what came out: and this 'cup' was inside the tank: Is this a P1 or P2 setup? I was going to order the walbro replacement item from RallyNuts which I know has been covered on here before and doesn't fit in the pump housing I have. Where can I get a standard replacement or upgraded walbro or equivilent pump for this setup? GSF only list one part and at ~£50 I'm worried it may be a bit s*ite. Thanks, Henry. Share this post Link to post Share on other sites
welshpug 1,737 Posted August 24, 2010 (edited) certainly looks like the P1/1.5 unts I've seen before, IIRC P2 are white plastic, not sure if the pump inside is the same. never bought a pump from GSF, but I think they are Bosch or Walbro anyway, best to give them a call. remove the pump unit from yu housing and see if their part numbers match. Edited August 24, 2010 by welshpug Share this post Link to post Share on other sites
Henry 1.9GTi 38 Posted August 24, 2010 just to add, from what I read on here it seems people don't suffer from fuel surge with this P1 setup. However my car surges really bad with anything less than 1/2 tank. Could this have anything to do with that 'cup' in the tank, or should there be other baffles as well? Share this post Link to post Share on other sites
MerlinGTI 3 Posted August 25, 2010 GSF pumps are phase 2 'no name' crap. Rally nuts ones don't fit. There are no aftermarket direct replacements. I bought a new Bosch unit (after a rally nuts one, a GSF one and a seccy hand Bosch!) for £80 odd from SC motorfactors. You get a pump only no housing. Share this post Link to post Share on other sites
Henry 1.9GTi 38 Posted August 27, 2010 yep exactly what I did. GSF had some cheapo pumps that looked like they would last 1 mile. Eurocarparts got me one in and despite me giving them an exact part number they ordered one with a different part number coz the system cross referenced it :/ They could also order direct from bosch but wanted £150 So in the end got Camberly auto factors to order one from bosch for £91 + VAT a little more expensive than yours but I have a pump the right size now! Share this post Link to post Share on other sites
