Uberderv 6 Posted August 12, 2010 Hi all, I have been building a 2.0l Hdi engine for my GRDT. I had stripped the engine loom down to remove anything that was not going to be used which included the original multiplug. My plan now is to find a new multiplug to fit to the Hdi/205 looms. I would like it to have plenty of pins to keep it tidy. Superseal plugs look good but the maximum I have seen is 6 pin and I would like 15. Just hoping someone might know where I could get one that size? I have seen normal 15pin connectors but I would like to avoid any moisture getting in there hence the superseal. Thanks in advance. Pete. Share this post Link to post Share on other sites
Cloverleaf 1 Posted August 12, 2010 I've got a bulkhead connector from here, not cheap though: http://www.fclane.com/Default.aspx Share this post Link to post Share on other sites
Uberderv 6 Posted August 13, 2010 I've got a bulkhead connector from here, not cheap though: http://www.fclane.com/Default.aspx How much did you pay if you dont mind me asking? How are the wires attached, do you have to solder them? Thanks for the link Share this post Link to post Share on other sites
