sceptre
Tyre/wheel Sizes
sceptre
Ok chaps, just a quick question here.
I have a 205 1.4i Sceptre which currently has 165/70T13 tyres on it.
I really want to get some original 205 alloys on it (pepperpots?) but I am very confused whether they will fit and if they will be legal? According to kwik fit I think the tyres for them are 185/55V15, this means they are wider and shallower right??
I've heard stories of having problems with brakes and wheel arches etc so I just want to check before I buy a set!
and wheel sizes are different to tyre sizes yeah?
Help? Confusion!
richsmells
These are pepperpots. They work well and look good on base models. Tyre size is usually 185/60 R14
It's the larger 1.9 Gti wheels (15") that sometimes cause problems with the arches on base model shells.
Edited by richsmells
Indeed - I used to run 1.6 GTi "Pepperpots" on my 205 XS...
vinorak
I´m using 165/65 R14 on my xs ;)img1602k.jpg
sceptre
1.6 pepperpots look like exactly what I'm after!
So does the R stand for Rim? So a 14" wheel would end R14?
And the figures are made up width/depth right?
muddatrucker
R stands for Radial, which is the way its constructed - pretty much all tyres are radial though as far as I'm aware.
Henry Yorke
The other ones that fit are 306 Harrier wheels from a 306 dTurbo.
And you want 185/60/14 tyres and not the ones Kwikfit said. The advantage to Harriers is that the centres push out so can be balanced easier.
Daviewonder
185 60 R14
185 is the width in mm
60 is the profile (60 = 60% of the width)
R means Radial type tyre
14 is the diameter in inches
Edited by Daviewonder
sceptre
Thanks everyone! Great info! I love this forum :P
PS, DOn;t use Kwik Fit, they are a rip off for anything
sceptre
finally got round to getting some sorted, looks fab. Thanks again for all the help! :D
