asdf205
Wont Start After Rain
asdf205
Thursday night it rained properly for the first time since i have had my 205. I got in the car friday morning and saw a bit of water on the passangers floor mat and thought there must of been a small leak from the sunroof. I then noticed there was some water dripping from the glovebox. Anyway i turned the key and the heaters started blowing fully (baring in mind the heaters never worked since i had the car i thought this was a bit strange). I drove the few miles to work no problem. At lunchtime i went out to the car to see if the heaters were still stuck on and they were so i removed the fuse and that was that. When it came to driving home from work the car turned over and wouldnt start. I tried this a few times and nothing. I went back to the car yesterday to try again and i have noticed i cant hear the fuel pump working. How would i go about fixing this? Has the water damaged anything important?
harryskid
Did you try it with the fuse back in?
large
As above but the heater motor should be off fuse 2 and the fuel pump if off fuse 14. I think thats the number the last one is the fuel pump.
asdf205
Yea i tried it with the fuse back in. I have checked all the fuses and they are all fine.
