205*31* 0 Posted July 13, 2010 Ok on fitting my sad I have pulled out one of the wires that goes into ecu temp connector no way I could repair it it was a very dodgy wire connection to be honest looked abit corroded I have found a redundant 2 pin female terminal connector in engine bay it has a pink and brown wire not doing anything so I have chopped wires of this and wired it accordingly to the 2 ecu temp wires works great now but what connector have I pinched I thinking possibly a fog light as I have none. anyone any ideas? Share this post Link to post Share on other sites
welshpug 1,737 Posted July 13, 2010 sounds like it bay be the reverse light switch plug. Share this post Link to post Share on other sites
Have-a-go-al 0 Posted July 13, 2010 Its not a brown plug that normaly sits on the rocker cover ? Appears to come from a crank angle sensor ? Allan Share this post Link to post Share on other sites
205*31* 0 Posted July 13, 2010 Its not a brown plug that normaly sits on the rocker cover ? Appears to come from a crank angle sensor ? Allan hi allan no it wasn't a brown plug was a white plug. I think welshpug is on the right track as I know on top of the gearbox there is a 2 pin male connector with nothing in it I am guessing this is the reverse light switch. Share this post Link to post Share on other sites
large 33 Posted July 13, 2010 I would go with WP as the plugs for the reverse light and the ecu temp sensor are the same. Share this post Link to post Share on other sites
