wah 0 Posted July 7, 2010 Hi all, I noticed last week whilst crawling about under my 205 1.9 that there should be a plate covering a inspection hole to view the flywheel, it has been fitted with a BE3 box and who ever has done the job obviously hasn't bothered to replace it !!, what I'm wondering is if anybody has one of these kicking about in the workshop / gagrage / shed that I could have or even know where I could get hold of one !!! Si Share this post Link to post Share on other sites
jord294 97 Posted July 7, 2010 i've got one mate do you want the bolts to fasten it on ? Share this post Link to post Share on other sites
wah 0 Posted July 7, 2010 Wonderful yes please mate PM me Si i've got one mate do you want the bolts to fasten it on ? Share this post Link to post Share on other sites
Henry Yorke 270 3 Cars Posted July 8, 2010 There are two types of these so you need to make sure you get the right one. I must have a BE1 one as the nice powdercoated one I have does not seem to fit my BE3 box This probably explains the reason yours is missing! Share this post Link to post Share on other sites
welshpug 1,737 Posted July 8, 2010 The is a difference between 1.6 and 1.9 due to the block stiffening plate. Share this post Link to post Share on other sites
jord294 97 Posted July 8, 2010 anyone got any proof there are different types, as i have only ever seen one type according to servicebox, only one part number aswell 2107.86 Share this post Link to post Share on other sites
welshpug 1,737 Posted July 8, 2010 are you 100% on that? because I can see 2107 A5 Share this post Link to post Share on other sites
jord294 97 Posted July 8, 2010 are you 100% on that? because I can see 2107 A5 well spotted mei Share this post Link to post Share on other sites
wah 0 Posted July 8, 2010 (edited) So which is it then as I need a BE3 box one ??? where abouts is it on service box ?? Edited July 8, 2010 by wah Share this post Link to post Share on other sites
Ryan 99 Posted July 9, 2010 The difference isn't between BE1 and BE3, it's between 1.6 and 1.9. The 1.9 has a shorter plate, otherwise it would catch on the bottom of the sump spacer. Share this post Link to post Share on other sites
Henry Yorke 270 3 Cars Posted July 9, 2010 Ahh ok. So I just have a powdercoated 1.6 one (though it would have fitted my engine originally before I fitted the alloy sump). What is the difference between the part numbers then? Share this post Link to post Share on other sites
welshpug 1,737 Posted July 9, 2010 (edited) 1.6 + non stiffener plate equipped XU9's, plus diesel engines and XU10's where applicable; 2107.86: all stiffener plate equipped XU9's, this would be the 1.9 MI16 and most 1.9 205 engines. 2107 A5 which is NFP as it happens. IIRC the low compression engines did not use them. Edited July 9, 2010 by welshpug Share this post Link to post Share on other sites
Henry Yorke 270 3 Cars Posted July 9, 2010 IIRC the low compression engines did not use them. Nope The used the 1.6 ones Share this post Link to post Share on other sites
S@m 156 Posted July 10, 2010 So which is it then as I need a BE3 box one ??? where abouts is it on service box ?? Although everyone seems to know this already ill just clarify, you will find it in the clutch plate/cover section or as servicebox puts it "CLUTCH WTHT RET MECH PLATE BEARING BUFFER" <--------that section; psa being concise as always! Sam Share this post Link to post Share on other sites
