GLPoomobile
Forgetfullness
GLPoomobile
I'm sure this will strike a chord with everyone, we all must have been here many a time. Share your stupidity with the forum :)
Here's mine from yesterday....
Slimline starter motor arrives from Anthony (thanks again). I go outside at 5pm to fit it. Went with the manifold off approach yet again as it's just the most comfortable way for me, and had it not been for some messing about with the alternator (that's an unrelated diversion to the situation) I reckon it only took me an hour to do it.
Putting the manifold back on, I manage to strip the end thread off one of the cap head bolts (they are too short now I'm using a PTFE gasket). So with one bolt missing I try to fire up the car and it won't run without lots of throttle. I assume it's sucking in a lot of air where the manifold is not clamped down properly.
Go indoors, have my dinner, have a look through the bolt collection and find an old bolt that looks to be right, go outside (it's getting dark now) and fit it. Start car, same thing, won't run. Have another check over with the torch - everything that should be connected is connected, and the manifold bolts are tight. Hmmmmm. I give up and figure I'll look at it this morning in the light.
Go indoors and have a bath. Whilst lying there I ponder what I've done wrong......and then I realise the stupid error.
I'd pulled off the breather hose from the AFM trunk to the ICV so that I could put the front bolt in for the coil, and forgotten to reconnect it :(:D It had sprung back to rest in the same place, hence I didn't notice my error. And of course with that now connected up this morning, it runs fine.
Don't you just hate it when that happens? :blush:
Edited by GLPoomobile
pugboyracer
On the glass half full side, don't you love it when an initial disaster turns out to be something straightforward? :(
maturin23
How about this one for dickheadedness.
Took the family over to France last month. Booked an overnight ferry to get to St Malo and a ticket on Eurotunnel to get back.
Realised shortly after I'd made the bookings that I'd booked the ferry for the Tuesday not the Wednesday by mistake. No big deal - extra day away plus it was cheaper.
Didn't look at the booking email from Eurotunnel. Left that laptop at home.
Coming back from the holiday, handed my credit card to the ticket guy - no record of my booking :( Ended up agreeing to buy another ticket at 'on the day' prices (over £300) but was pretty pissed off that they'd lost my booking.
Got home, all ready to get on the phone and sort out my refund. Turns out if I'd checked my email I'd have realised I'd booked it for the weeked before.
£300 down the drain, just by being a twat.
willmounsey
When I was fitting my engine in the pug, I thought i'd had everything connected up so went ot turn the key and it was just turning over.
After a while of going over things and even pulling the injectors out to see if they where firing no joy, getting aggressive at this stage I went to have a look at the fuel pump because no fuel was coming through and what do i find sitting in the back?.. the bloody ecu, I swear I nearly cried :( .
Plugged it in and it fired first time :blush:
Oh well these things can happen.
Will
GLPoomobile
AFM sitting in the back :)
One of the earliest serious run-ins that I had with this current (Mi) 205 was when I was panicking about the oil pressure all the way home from Edinburgh to London because the sender wire was dodgy. So my mind wasn't exactly in a fit state at the time. I'd also been having starting problems with the car, on and off, since buying it. Pulled in to services around the midlands and checked things over again. Went to start it and couldn't. Check a few things (in the dark), and still no joy. Saw a group of young Frenchies (the irony :( ) sitting on fence having a fag break so called to them to give me a bump start. Still wouldn't work so I sheepishly apologised to them and sent them away.
Then I remembered that my alarm auto immobilises after 30 seconds of the ignition being off. FACE>PALM :blush:
gixxerash
Then I remembered that my alarm auto immobilises after 30 seconds of the ignition being off. FACE>PALM :(
Done something similar again with the 30 sec re arm on my alarm i left the keys in the ignition and the doors locked left me standing outside in the rain trying to find someone that might have a coat hanger on them :blush:
I turned that feature off after that.
Edited by gixxerash
hcmini1989
I put a head on rover last year got it all ready for the start up and another mechanic comes around from the boot of the car with a set of lifters d*ckhead.
Allso when i used to race motorcross i rebuilt the bottom end on my kx250 put it back together engine back in cracked it up tried 1st gear and nothing ah mate was standing there with a gear in his hand TW*T.
Happens to us all mate my favorite for remembering or working out what you`ve done wrong is on the toilet :(
muddatrucker
Ive bought return tickets the wrong way round before, blagged it though!
richsmells
I was using my girlfriend's dad's workshop ramps to drop the oil. I fitted the new filter, replaced the sump plug and lowered the car. Then my girlfriend stopped by and we popped out for lunch.
When we came back, I got in the car, put the key in the ignition and paused for a moment. A synapse somewhere in my brain was telling me not to turn the key. Then I suddenly remembered!
I'm never leaving a job half finished again. (or letting myself be distracted by women :( )
Edited by richsmells
GLPoomobile
Wondered why I was getting some clonking while driving my old Civic. Had forgotten to do the wheel bolts up after putting the wheels back on. That was a close one.
But an even closer one was the day I pulled the steering wheel clean off whilst driving around J1 of the A1(M). I've since got a proper quick release hub so I never forget to secure the wheel properly in future!
RHULPUG
Oh wow, that's pretty outrageous! :)
A few years ago I got out at a petrol station to take my jacket off and put it in the boot prior to the long journey home. The problem was the engine was still running, I closed the drivers door, then the central locking activated and all the doors locked.
The second problem arose when I realised that the cooling fans weren't cutting in, the engine began to throw steam out from under the bonnet. I couldn't just stand there and watch my newly purchased 205 boil to death, so I tried fitting my fingers behind the rear OS quarter window in order to open it. Almost managed to grab the opening fastener, then smash, the glass shattered, slicing through my knuckle on my index finger. Immediately turned it off, filled it up with coolant etc, then drove home fine, albeit with a bandaged up right hand, and in need of a hospital. Several years later still scarred on my right hand index finger knuckle!
...moral of the story, should've just smothered the exhaust to cut the engine!
gixxerash
That's hardcore :)
Daxed
Back in the day of three TV stations and distributors with points I learnt the reason why all documented procedures of car DIY maintenance begin with 'disconnect the battery'.
I can't remember what I was actually working on, I do know I had a 3/8" ratchet and I was tightening a main live connection, probably starter motor.
I obviously added a little more rotation to this particular turn and was suitably rewarded by a loud 'crack' and an accompanying 'flash'. This caused a couple of involuntary body reactions on my part.
The first was leaping away backwards from the engine bay, catching my heels on the raised kerb (this pantomime was conducted outside the house in the road to entertain the neighbours). I fell back heavily onto the pavement on my arse. Normally a stumble such as this would be likely to cause a little soreness in the area of ones 'seat'. I however was incredibly lucky, as due to my bodies second involuntary action, s*itting myself, I had a very comfortable, soft and padded landing.
This normally somewhat upsetting bodily function also had the advantage of helping me to bounce back to my feet and have a peer back into the engine bay.
In the couple of seconds that I had been otherwise engaged, the situation in the engine bay had changed somewhat. The end of the ratchet was already glowing a nice cherry red, this is an odd thing to witness, when ones only intention was to torque up a nut.
The next event was dramatic enough to completely take my mind off what was happening in my shorts. The red hot ratchet handle burnt through the copper brake pipe that it was jammed against and immediately ignited the now leaking brake fluid.
Things were escalating quite quickly now and apart from using my soggy and somewhat heavy jockeys as a fire blanket I didn't have a clue what to do.
I got things under control in the end, didn't lose the car, but did lose the shorts.
I now disconnect the battery prior to pumping the tyres up.
Edited by Daxed
GLPoomobile
I can't see anyone bettering your story Daxed :( I think the rest of the topic is going to be a bit of a disappointment after that tale! :)
GeorgeXS
Haha, well thats made my week Daxed :)
DrSarty
Yeah Daxed, that was brilliant!
And the amount of s*it I get from people on here when I say batteries can be bloody dangerous. QED.
I've forgotten the ECU before.
I've forgotten gearbox oil.
I've even forgotten to reconnect the battery, stating out loud: "Oh FFS now what?" <_<
The expression as one scratches one's head, confused as hell is priceless and should be captured.
Daviewonder
When I was younger I rode my pushbike to youth club only to realise as I parked my bike that I still had my slippers on <_<
zebedy101
Some quality mistakes going on here.
I have attented the wrong funeral,
Left my handbrake on out of gear in the paddock at Cadwell after coming off track, turned around too see my car running away fortunatly a couple of people stopped it before it hit the portacabin.
Driven up a walkway at a college thinking it was a multi story carpark.
I forget a lot of things also I have forgotten where my car is a few times and many other slightly dense accidents. I am accident prone I tell thee.
ORB
I once lost the plot with a bloke who was giving my wife s*it on a night out, he was one of the bar keeps in a crappy pub, anyway, long story short, I battered the wrong bloke.
I have felt s*it about this for 7 years now and always buy the lad a pint when I see him now.
woodsy
Remember when first got my 205 16years ago putting the finishing touches to motor to start it up after doing the head gasket and couldnt find 1 of the spark plugs so put another set in.When i went for first start up the throttle stuck fully open and realised the lost plug was left in the throttle body for some stupid reason.Then to finish it off whilst leaning under bonnet i knocked the bonnet stay so bonnet hit me on head which cracked my head forward and smacked my top lip and nose into the strut brace and was pouring with blood
GLPoomobile
Yeah, I was just thinking that earlier (sadly enough) :lol:
I used to drive to work even though it was less than a 10 minute walk (hey, it was Edinburgh, that place is f***ING COLD!) and there was a Somerfield in the middle of the journey (OK, doesn't really qualify as a 'journey' per se :D ). Stopped to pick some shopping up and then went home.
Took me f***ing ages to work out where the f*** my car was when I realised it wasn't outside the flat the next day :lol:
giveitsomebar
most recent i took the rollcage out of the 205 drove down the road hearing a loud banging thinking hum that sounds odd turned around to realise all 4 beam bolts were finger tight. also poured oil into someones car with the oil filter off come out the bottom as quick as i could put it in theres me thinking s*it me not much on the dipstick! to look down and find my shoes covered in it..
scotty
Some good ones but Daxed has got to be the best i cant stop laffing :lol:
IIRC (and it would be ironic if I didn't given the title of this thread) you claimed car batteries electrocuted people and it was that which is disputed, not that batteries are dangerous.
DrSarty
There are some evil batteries out there though. :lol:
