Carbs4me
Engine Cut Out While Driving?
Carbs4me
hello all,
Just wondered if you guys have encountered a similar problem.... i was driving around some of the local country roads, i stopped turned around set off just got into 3rd gear, at around 30Mph when all of a sudden the car jumped and no response came from my thottle.. when i pushed the clutch in the engine just died and wouldnt start again, i left it for 10-20mins and tryed to give it another wurl but it would barely idel with my thottle fully open and max revs i could gain was 2,000 RPM. after about 30seconds of having the thottle fully open it slowly creeped upto 3,500RPM which from that point the engine seemed to be completely fine but letting it drop back below 3,500RPM the problem would start again, i tryed to limp it home, but due to lot horses been on the road i had to just leave it...
Currently the car will not start
I personaly think it could be my dizzy? sound familer to you guys?
MrG
ignition amp or coil?
Carbs4me
If it was the ignition amp would it still fuel? because fuel is getting in there from the pump itself..
i have a spare coil pack but no spare ignition amp, is this located on the right hand side of the engine bay?
AJA_GTi
Clean the AFM with carb cleaner and it'll sort the problem mate i'm fairly sure. Sounds similar to what happened to me last month :angry:
Edited by AJA_GTi
Carbs4me
Thanks i will try that, gunna order a new Dizzy aswell just to be sure!
Do i spray the carb cleaner inside the AFM? and wipe or just leave it in there?
is it still an 8 valve and what year is it?
Do the rev counter drop stone dead when this happens? or does it follow the revs dying?
Carbs4me
yes its still an 8v.. and the reg is F so i think that would make it 89-90?
yes it droped straight down with no hesitation, the engine pretty much cuts out just as quickly as the rev counter drops down... soon as my foot is off the accelorator it cuts out...... it does follow the revs when rolling with the clutch out and in gear...
If the rev counter does follow revs when rolling along in gear, albeit without any power, I'd try another Tachymetric relay as its clear you still have spark, if you did not the rev counter would die straight away (or do a merry dance as they often do when spark faults occur)
If you can replicate the fault check that the fuel pump is getting power.
Carbs4me
ok thanks for the suggestions guys i will try them and get back to you in a couple of days once i get it home... Fingers Crossed!
AJA_GTi
Whip it off and spray the probe and hinge bit then let it dry and re asemble.
Worked for me mate
Carbs4me
hello again,
alittle update... cleaned the AFM with carb cleaner still no change, although its looking a dam site better! my dizzy cap dus look like its seen better days, got anew 1 today, gunna fit it and hopely it will go!
Everything is in working order, just seems like the engine wants to go but its not quite there, but the sparks from the plugs wernt that impressive.. hopely a change of dizzy will solve it
Edited by Carbs4me
Carbs4me
The problem was due to the Ignition Amp, thanks guys!
