rob.duke
Vacuum Sunroof Removal
rob.duke
Hi Folks,
Finally got round to starting the job of removing and blanking my sunroof.
TBH it's a bit of a mare cos stuff is corroded etc. but takin stuff off is always easier :(
What is the correct thing to do with the Vac tube that runs up the A Pillar, cut it? stuff it down pillar? blank it off?
As ever, any help is appreciated.
Rob
norm
Hi Folks,
TBH it's a bit of a mare cos stuff is corroded etc. but takin stuff off is always easier :o
Rob
:ph34r:
hi rob could you tell me why are you removing the sunroof? only asking cos i've just bought a 205gti and the seller tells me that a cable has broke,was that your problem
norm
rob.duke
Hi Norm,
Removing sunroof as it is basically a track car, the whole sunroof and workings weigh around 16kg so it's worth the effort removing it. I would also rather have it plated than have all that glass over my head if it ever went over!
Cheers Rob :ph34r:
GilesW
I did this last weekend and have a related question which may help you and me (hope you don't mind me asking):
I was just going to plug the vacum feed from near the brake servo and remove and bin the vac tube up the A pillar.
So I merrily pulled what I though was the vac tube to the sunroof from within the engine bay - it popped off a connector behind the dash somewhere ( I think) and then I realised there are 2 vac tubes going into the car:
1 through the bulkhead near the throttle cable (the one I pulled), and
1 goes behind skuttle panel in engine bay.
Which is the sunroof vacum hose, and where does the other one go?
rob.duke
I actually did the same as you, i was pulling at the hose like a bird pulling a worm out of a hole from inside the car and then tried from under the bonnet, the hose just pulled away from something and i don't know what!!
I think i'll plug the sunroof one at the pipe end and push it in the a pillar!
How have you decided tp blank your sunroof?
Rob ^_^
