asdf205
1988 1.6 Clutch Adjustment
asdf205
Just picked up my 4th 205. Its a near enough immaculate low milage 1988 1.6 gti in red. Has a slight problem of the bite point being too low. How can i adjust the clutch cable?
Couple of nuts (10 and 13mm) on the gearbox end of the clutch cable - tighten then to raise the bite point, and loosen to lower it.
205*31*
been getting crunching gears had gearbox oil changed hoping it would sort it still doing it. I think my clutch biting is alittle low and maybe its not fully disengaging so I have just been out and adjusted mine abit higher will see how that goes, on the same note on my clutch end I had 2 10mm nuts not a 13 there was abit of a pain too didn't have 2 10mm spanners so had to use a rachet :ph34r:
