flyfisher 6 2 Cars Posted June 2, 2010 just finished my mi16 1905 convertion one problem i would like advtce on if i should have to change alternater getting the top large bolt out how. look at very least thazt you would have to release engine from mounts in order to clear o/s/f chassisleg /inner wing any idears any one had this problem thanks peter Share this post Link to post Share on other sites
Anthony 1,003 Posted June 2, 2010 You don't have to remove the bolt completely, only undo it so that it's free of the nut on the alternator (opposite end to pulley) Share this post Link to post Share on other sites
flyfisher 6 2 Cars Posted June 2, 2010 many thanks of course that makes sense Share this post Link to post Share on other sites
dee205 3 Posted June 2, 2010 The bolt is stepped so when you screw it out so far the thinner bit allows the alternator to slot out. Share this post Link to post Share on other sites
quagmire 0 Posted June 3, 2010 To get my alternator off I had to remove the grille, slam panel, fans and rad to get the right amount of clearance to get it out. Share this post Link to post Share on other sites
Simes 248 2 Cars Posted June 3, 2010 (edited) That top bolt is more of an arse when you've just spent 4 days fitting an engine and running gear and then dropped off the engine hoist to the hire shop. Then when going to fit the alternator realise that you've left that really long bolt out. Edited June 3, 2010 by Simes Share this post Link to post Share on other sites
dee205 3 Posted June 3, 2010 That top bolt is more of an arse when you've just spent 4 days fitting an engine and running gear and then dropped off the engine hoist to the hire shop.Then when going to fit the alternator realise that you've left that really long bolt out. Bummer. I'd have settled for a cable tie! Share this post Link to post Share on other sites
Anthony 1,003 Posted June 3, 2010 That top bolt is more of an arse when you've just spent 4 days fitting an engine and running gear and then dropped off the engine hoist to the hire shop.Then when going to fit the alternator realise that you've left that really long bolt out. You'll only make that mistake once Share this post Link to post Share on other sites
S@m 156 Posted June 4, 2010 I once got a strong friend to lever the engine out of the way with a crowbar (just a few extra mm) to remove the alternator itself on a mi16x4, but with regards to the long bolt; i thought there was a small access hole in the chassis leg/bodywork directly in line to extract it. But maybe thats on 405's, also, my 306 with a 1.9 Mi has an access hole in exactly the right position for this, even though the original engine did not require it at all! Sam Share this post Link to post Share on other sites
