2052006 10 Posted May 9, 2010 Looks like I'm going to have to cut the main feed and return (metal) fuel pipes under the car to make it easier to solve a leak/connection problem. What is the best (ie. safest) way of cutting these pipes? Thanks Pete Share this post Link to post Share on other sites
timb1046 1 Posted May 9, 2010 a pipe cutter would be best. anything that cuts with a scissor/crushing motion wont work as it'll just crush the pipe down. so a pipe cutter that goes around the out side with a sharp blade a few times until the pipe cuts would be best IMO Share this post Link to post Share on other sites
2052006 10 Posted May 9, 2010 Haven't got a pipe cutter. Am I right in thinking a hack-saw would be a stupid idea in terms of safety?!! Share this post Link to post Share on other sites
timb1046 1 Posted May 9, 2010 well disconnect the lines from anything else like other fuel lines so that they dont have fuel near them. and then a hack saw is fine, just use a sharp blade and use very little pressure so that you dont crush the pipe at all. Share this post Link to post Share on other sites
Tom Fenton 1,650 Posted May 9, 2010 A hacksaw will work, a pipe cutter for a few quid will be much easier. Share this post Link to post Share on other sites
dumbiron 0 Posted May 9, 2010 A hacksaw will work, a pipe cutter for a few quid will be much easier. And decrease the risk of metal bits getting inside the fuel pipes . Share this post Link to post Share on other sites
timb1046 1 Posted May 9, 2010 And decrease the risk of metal bits getting inside the fuel pipes . although the filter is nearer the fuel rail than the metal pipes so dont worry too much about it, just try to be careful Share this post Link to post Share on other sites
BusEngineer 7 Posted May 9, 2010 I use both regularly at work to cut diesel fuel lines, would pick a proper pipe cutter everytime if it was always that easy, to be honest i pick pipe cutter as it produces a lot cleaner cut, just depends on space and access Share this post Link to post Share on other sites
harryskid 193 Posted May 9, 2010 You can get small pipe cutters that will cut 10mm or 8 mm and can be used in tight places. Also you can get ratchet ones. Share this post Link to post Share on other sites
2052006 10 Posted May 9, 2010 Got myself a small pipe cutter, as said, only a few quid from B&Q. Worked a treat. Thanks all Share this post Link to post Share on other sites
