blessed6383 0 Posted May 6, 2010 will it run without the tps wired up as im running the mi16 inlet on the 8v wiring? and the plus are different also the wire for the icv does not reach (shall i just make it longer?) or can this be left off or will it stop it from running? cheers guys Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted May 6, 2010 will it run without the tps wired up as im running the mi16 inlet on the 8v wiring? and the plus are different also the wire for the icv does not reach (shall i just make it longer?) or can this be left off or will it stop it from running? cheers guys Mi16 TPS is the same as the 8v TPS so it should fit straight on without any problem. The engine will run without the icv plugged in, unplugging it either raises or drops the idle speed very slightly iirc. If your using the 8v wiring loom then it doesn't have an ICV plug anyway though. Graham. Share this post Link to post Share on other sites
blessed6383 0 Posted May 6, 2010 ah i see i have a black 2 pin plug that doesn't seem to go anywhere then which is confusing me and dont have a 3 pin plug for the tps. i have 1 joined from the crank/flywheel sensor going back in to the main loom and another from the ignition module to the 8v dizzy, is this wrong? Share this post Link to post Share on other sites
Anthony 1,003 Posted May 6, 2010 ah i see i have a black 2 pin plug that doesn't seem to go anywhere then which is confusing me That'll be for the SAD - remember, this is an 8v loom meant for an 8v engine, which doesn't have an ICV! and dont have a 3 pin plug for the tps. i have 1 joined from the crank/flywheel sensor going back in to the main loom and another from the ignition module to the 8v dizzy, is this wrong? That's your problem. 1.9 8v non-CAT's don't have a crank sensor - they get the timing signal from the dizzy. That lead you've plugged in is the TPS one. Share this post Link to post Share on other sites
blessed6383 0 Posted May 6, 2010 That'll be for the SAD - remember, this is an 8v loom meant for an 8v engine, which doesn't have an ICV! That's your problem. 1.9 8v non-CAT's don't have a crank sensor - they get the timing signal from the dizzy. That lead you've plugged in is the TPS one. nice one bud will try this cheers Share this post Link to post Share on other sites
