blessed6383 0 Posted May 3, 2010 i fitted my shafts in my mi16/gti6 box today and the n/s (short shaft) doesn't seem to all the way in the gear box. there seems to be about 10mm gap is this normal? as i tryed to push it in further but it didnt want to go and weren't going to force it just incase i did some damage it fits in the hub fine so i assume its ok but thought id ask Share this post Link to post Share on other sites
Baz 421 Posted May 3, 2010 (edited) edit. '6 box, i didn't read properly! As Graham says below! I have a shaft alone for the inner CV if you need one. Edited May 3, 2010 by Baz Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted May 3, 2010 The GTI-6 diff is different to the original Be3 one (& so are the later 405 & 306 etc diffs). You either need to swap diffs or driveshaft ends so the shafts fit into the diff properly. Graham. Share this post Link to post Share on other sites
Tom Fenton 1,650 Posted May 3, 2010 http://forum.205gtidrivers.com/index.php?s...iveshaft++short Share this post Link to post Share on other sites
blessed6383 0 Posted May 3, 2010 cheers guys did think it was a bit strange it not matting up baz pm'd mate cheers Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted May 3, 2010 Now, if you tried a search... Graham. Share this post Link to post Share on other sites
blessed6383 0 Posted May 3, 2010 hey no meany face on this one lol how come? Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted May 3, 2010 Because I posted that one first but I can edit one in if you want? Once again you didn't try a search first & just went ahead to ask a question which had already been covered. Graham. Share this post Link to post Share on other sites
Tom Fenton 1,650 Posted May 3, 2010 Graham is right. I knew the reason behind your problem, but as a test I did a very quick search. I typed in "+driveshaft +short" and got an answer straight away, easy. Share this post Link to post Share on other sites
