blessed6383
[car_overhaul] My Pug Mi16
blessed6383
the start of the unfinished project i bought lol dont do this as just causes my head ache daily lol but end result will be worth it i hope :)
the start as i bought it registered as a 1.4i but they dumped a 1.9 in there and it was oringinaly a 1.9gti
the inside
the engine only just hanging in as they hadn't bolted it to the mount or even have the right mount for the car
the 1.9gti engine and box removed
a few bits of rust to deal with as somewhere along the line someones spilt brake fluid
the modified subframe its a gti subframe but they moved the bracket that holds the gear linkage in place to accomadate the 1.4 gearbox
so i have had this cut off again and moved to its orinal place for the gti6 box
a few bis painted to loo a bit nicer
blessed6383
strippin out the engine bay of wiring and brake lines
the wiring loom out and recovered with red plastic protection a nice little tidy up for only £20
a few more bits painted
the radiator mounted to the cut back fan housing to give a bit more clearance to the mi16 inlet manifold
had the inlet manifold sand blasted to clean it still desiding weather to have it painted silver or have it chromed
blessed6383
the engine and gearbox
the peddle box painted was a pain in the arse to remove lol
the engine bay preped and primered
second coat of primer applyed
sprayed a bit of the car today but ran out of paint and was check colour difference as couldnt find right match seems its had a custom colour mixed for the body not to fussed about the difference for this year as it will come back off the road when winter comes for some carbs/throttle bodys and a ful body respray
this is as far as i have got so far so lets hope he weather holds up :)
spark-plug
nice prodject :) .After the sprinting season has finished im either going to work on mine make it look proper nice or buy another one as a project like this :D
blessed6383
got the paint done yesterday and started rebuilding today.
205BigTosh
looks great, fantastic , keep it going
blessed6383
not updated this thread for a while so will add a few pics of how far its got
few picures of the engine and "6" box fitted
another wth the inlet and few other bit put on
another with the dizzy convertor which has now been removed and fitted the bx16v loom and ecu for less hassle as could not get it to idle properly
few pics with the front end built up
the terrible bonnet vent will be going when i get round to it as will be fitting an auto bonnet instead
Edited by blessed6383
blessed6383
started to bleed the rear brakes and found that there was a bit too much movement on the rear beam so this has now been stripped ready for a rebuild along with a lick of paint
the beam removed
one side of the beam had seen better days B)
the shagged trailing arm. other sides not much better so will be replacing both
the beam in bits
the new 17's that wil be refurb'd but still might stick with the 15's
blessed6383
well not done an update for a while so heres a few pics of the painted rear beam and mi16 leathers fitted, did have to have some small brackets made up to fit the seats to the 205 subframes as the 405 subframes are about an inch wider and they do fowl the handles to lift the seats but dont plan on haveing many people in the back.
the rear beam has been fitted with solid beam mounts and uprated poly bushes along with a full rebuild kits (beaings etc) ad new bolts/nuts, also uprated shocks not yet fitted
have also now fitted a bx16v loom and got rid of the dizzy convertor and gti loom so is running full mi16 set-up
harryskid
Nice work, whats the spoiler on your car from?
