Guest C_F
Seat Height
Guest C_F
Is there any way of lowering my front seats.My brother's 1.9 has the same seats but they sit alot closer to the floor.I recently sat in another 205 GTI and the seats in that were the same as my brother's.
My seats are standard.
Can anyone make a suggestion to bring my seat lower to the floor???
Edited by C_F
Guest doughboy
yeah,
under the runners you will find some round black plastic spacers...
try fitting seats without these..
Gary
For some reason,they used different thickness washers for different cars.Some are black plastic ones,about a cm thick and some have metel ones only a couple of mm thick.
Easy job to replace them ;)
Guest Gar
I tried taking the washers out of mine, but found the sliding mechanism dragged on the carpet, so I put them back.
Guest Hungrytang
The reason that there are two different types of washers is that the two subframes are quite different
The thicker washer was used to around G reg I think and the the thin type after
not really sure why?
I've taken those washers out of loads of 205s now and never had a problem with the seat hitting the carpet.
Simes
Yep! I've taken them out of mine and no problems - mine are the later 9/10mm black spacers.
fiji bob
did you put anything in their place?
Simes
No, I was planning on using some mud guard washers but since it all seems to work alright I haven't bothered.
I didnt replace them with anything either ;)
fiji bob
have you taken the seats out since then? i did notice some moisture under the spacers the last time i took the seats out it might be worth finding a thin washer so the seat frames dont rust
Guest Batfink
use silicon sealer on the underside to stop the moisture getting in???
Hilgie
I have taken the washers and the mechanism for getting in the back out. Now they sit quite low. If someone needs to be in the back he/she'll have to go in through the passengers side.
