Craig89 0 Posted March 13, 2010 Hi, im having a bit of trouble with the twin webers on my TU rallye. At around 2000 RPM they just start coughing and spitting but the car still seems to run ok. If anyone has any ideas on what it might be, that would be great. Heres a video of what is happening: View My Video Cheers, Craig Share this post Link to post Share on other sites
iamjackiechan 0 Posted March 13, 2010 have you had the carbs balanced and jets to suit you setup Share this post Link to post Share on other sites
Craig89 0 Posted March 13, 2010 have you had the carbs balanced and jets to suit you setup Yeah, set up by Sandy Brown. It used to happen every now and then which i could accept but it just has been getting more frequent Share this post Link to post Share on other sites
iamjackiechan 0 Posted March 13, 2010 what fuel pump, pressure regulator are you running. also may be worth popping the jets out and just having a general snoop around the carbs make sure nothing is damaged or not how it should be Share this post Link to post Share on other sites
Guest steveontwin40s Posted March 13, 2010 Hi, i had twin 40s on my 1.6 gti 205 and they used to backfire, i removed the carbs and found the inlet manifold gasket had a split in it, worth a look. plus have you got a adjustable fuel pressure regulator, it is very important 2 have it spot on. how long was it set up? they go out of tune so fast! hope this helps. Share this post Link to post Share on other sites
Bally123 0 Posted March 13, 2010 Air leak by the sound of it, you could try running the same conditions in the dark - chances are you'll see a spit of light with every cough, is the distributor and or servo connected to the manifold? (if so try blocking off the manifold tappings) I would suspect Missab gaskets are leaking - but I have also had similar experience with a vacuum advance tapping on the manifold- this showed up in the dark as above Good luck... Bally Share this post Link to post Share on other sites
Craig89 0 Posted March 15, 2010 Thanks for the replies everyone. The gaskets between my manifold and carbs is quite thick and looks like a see through plastic material, when i hold it at 2k RPM in the dark you can see flashes at these gaskets. The only hole in the intake manifold is for the vacuum for the brake servo and that appears to be sealed. I will remove the manifolds and carbs and see what the gaskets are like. Cheers, Craig Share this post Link to post Share on other sites
MrG 3 Posted March 16, 2010 I'd agree with bally, sounds like one or two have failed. Share this post Link to post Share on other sites
jonnygoodhand 0 Posted March 16, 2010 Yeah, set up by Sandy Brown. It used to happen every now and then which i could accept but it just has been getting more frequent If you don't mind me butting in, they were originally set-up by Sandy, but were later fettled by Aldon Automotive, in order to get it past a rather strict MOT guy. Share this post Link to post Share on other sites
MrG 3 Posted March 16, 2010 so could be running a bit lean? Share this post Link to post Share on other sites
Craig89 0 Posted March 17, 2010 I have had the carbs and manifolds off tonight and checked all gaskets and they are fine, like new tbh, so cleaned everything up and tightened everything up, refitted them and tryed again. Still doing it unfortunately. Next i wondered if it could be timing as i, fairly recently, changed the rotor arm. So i moved the rotor arm round a bit and managed to get it not to spit. Im not sure if this is the correct solution of the problem though, is there an easy way of checking that my car is timed up correctly how it is now or how it was before? Cheers, Craig Share this post Link to post Share on other sites
