joe1joe
Converting Standerd Dampers To Coilovers
joe1joe
i was on about using the orginal insert like jersey pug??
i did post it on here but dont know how to do a link. it was titled Diy Coilovers, just put one together.
DIY coilovers
Graham.
davidc
I, personally, would use an uprated insert or uprated shock altogether as using the std insert with much harder springs will result in a very bouncy ride...i.e. the shock is not matched to the spring
Its a good post though...the one about DIY coilovers !
Cheers,
David
Dazza
IIRC the coil-over kits can be done a couple or three ways , they usually use the Escort 40mm inserts albeit the Peugeot are 41mm and are propper expensive ...
Firstly why do you want to convert to Coil-overs ? If its for adjustment fine ...
My Advise would be to Buy some Standard Platform GP N Yellow Billies and some 180lb springs ..
andy0075
I have made such a conversion a month ago with my Bilstein race-dampers (40mm inserts)
and the result is quite good. The Bilstein dampers have 52,4mm outer diameter and the
tube i have used has 52mm inner diameter.
The whole work was finished in two hours !!
You can see some pics here ( click on "Bastelecke" ) : http://www.peugeot-racing.at.tf/
Andy
davidc
Andy
Nice work !
Just a couple of questions....why did you use 2x short H&R springs, what i.d. are these & what poundage ?
Also, where is it you get these kits from ?
Cheers,
David
Dazza
Ditto ...I like that , quick and simple and most importantly recession friendly ...
I Have a set of those dampers in the loft ..
andy0075
Thanks that you like it !
I bought the kit from "timms-autoteile"
You can find it here on page 19 : http://www.timms-autoteile.de/cat/timms-green.pdf
It is also available in UK for less money :
http://www.compbrake.co.uk/SUSPENSION/SUSPENSION4.html
But with shipping to Austria where i come from it costs in the
end the same as at timms-autoteile
The springs on the picture are 25N/mm helpersprings
and 100N/mm mainsprings.
25N/mm....140pounds/inch
100N/mm...550pounds/inch
The car is for autoslalom use only.
Here you can see a short video from some of my opponents from last year :
Andy
foreigner
Well it sounds like very good and cheap conversion.
Definitely buying that.
I got gti-6 dampers, what spring rate should I get for it?
Dazza
Andy
Thats Handy , Iam ordering tommorrow
You don't want to go too high on the spring rate, as the damper will not cope with any significant increase over the standard rate.
foreigner
thanx for that,
so what should be the ideal rate for fast road car?
foreigner
What is the standard gti-6 spring rate as I want to do this conversion and want to order springs and don't want them to be too hard for dampers.
anyone??
