Spiky 37 Posted February 9, 2010 Looking to get a new gauge for the Fuel level, VDO sell two types 0-1/1 (for Float-arm type sensors) 0-1/1 (for tubular Dip-Pipe sensors) which would i need? Or if someone has a different make gauge and is working ok, what do you have? Share this post Link to post Share on other sites
jackherer 543 Posted February 9, 2010 The standard sensor is a tubular dip pipe so I guess you need one of those, I doubt the calibration will be right though, unless you fit a matched sensor and gauge. I have a float arm type sensor I plan to fit (made by Sunpro) that looks like it will calibrate to the 205 tank (according to the specs) as I didn't know any dip tube types were available for aftermarket gauges. Share this post Link to post Share on other sites
Spiky 37 Posted February 9, 2010 Good info, so maybe full won't show full then, maybe will have to try, if not, will have to do what 309pug does and uses a multimeter and checks resistance and that tells him how much fuel is in the tank, but that's just hassle I don't need unless infer a spa digital gauge am see if that's programable Share this post Link to post Share on other sites
jackherer 543 Posted February 9, 2010 You can see the type I have on ebay, item 290380093940 Share this post Link to post Share on other sites
