Weser 30 Posted January 29, 2010 Hi, Im going to replace my fusebox as it has loose connections in at the moment. My question is before I start unplugging the connectors, are all the connectors different sizes so I cant get them mixed up? Or should I do them one by one so as not to mix them up? Also can I use any gti fusebox or does it have to be a 1.9 fuse box. (My car is a Ph 2) Thanks Andy Share this post Link to post Share on other sites
dan_cole69 0 Posted January 29, 2010 Hi, To answer part of your question yes some of the plugs are the same/similar so it would be an idea to number them and have a diagram to cross referance. As for the fuse board I think you will be fine using any injection model fuse board because (and I think im right in saying please correct if wrong) the only difference between injection fuse boards and carb fuse boards is the connection for the fuel pump (small yellow connector 2 pin IIRC). Hope this helps Dan Share this post Link to post Share on other sites
Weser 30 Posted January 30, 2010 Cheers Dan, Just what I wanted to know. Thanks Share this post Link to post Share on other sites
pug_ham 242 3 Cars Posted January 31, 2010 None of the fusebox plugs can be mixed up afaik, they are all specifically keyed for one place on the fuseboard. As shown in this picture. Graham. Share this post Link to post Share on other sites
Weser 30 Posted January 31, 2010 None of the fusebox plugs can be mixed up afaik, they are all specifically keyed for one place on the fuseboard. As shown in this picture. Graham. A picture even better Cheers Share this post Link to post Share on other sites
Daviewonder 533 3 Cars Posted January 31, 2010 None of the fusebox plugs can be mixed up afaik, they are all specifically keyed for one place on the fuseboard. Im sure they even have coloured dots on the board next to the plugs aswell so you just match the coloured spots on the board to the plugs making it even easier. Share this post Link to post Share on other sites
