Guest Pingo Posted January 15, 2010 Hi, I got a problem with my 205 GTi.. The right rear wheel has started to lean inwards the car, like negative camber. I can also hear the wheel rubbing against the car when I drive through roundabouts etc. What is causing this? Will I have to fit a new rear beam to solve this problem? Thanks in advance, Kris (heres a pic of what it looks like) Share this post Link to post Share on other sites
Tom Fenton 1,650 Posted January 15, 2010 That will be a beam bearing problem, no way of telling any more until you get it apart, but be warned that you might find the trailing arm shaft and main cross tube scrap and needing replacements. Share this post Link to post Share on other sites
Anthony 1,003 Posted January 15, 2010 Very common and a search will reveal pages of information. Basically, the beam beam bearings will have collapsed/disintegrated, and if it's now so cambered that the tyre is rubbing on the inner arch, I'd hazard a guess that the shaft will be grinding away on the inside of the beam tube and caused it to become oval, rendering it scrap. In other words, yes, it realistically needs a new beam - be careful of just putting another used beam on the car, as most original beams that haven't been rebuilt are usually also in poor condition internally. Share this post Link to post Share on other sites
Guest Pingo Posted January 15, 2010 (edited) I better have a look at it then. Thanks for the fast replys guys! Edited January 15, 2010 by Pingo Share this post Link to post Share on other sites
