humanz 3 Posted January 6, 2010 Anyone have any photos of the driver's side (O/S) driveshaft from a 1.9? Particularly interested in the end that goes in to the hub. Saw one at the dealership that had a ring of teeth by the bell shaped part by the end that fits into the hub, but close to the boot at the joint (not sure about the names of these things). The guys at the dealership were not able to 100% say it was a 1.9 driveshaft, but it was in the box with the correct part number. I've never seen a 1.9 driveshaft before, so wanted to check before I buy. Share this post Link to post Share on other sites
Tom Fenton 1,650 Posted January 6, 2010 The teeth are an ABS sensor ring. This will work on an ABS or non ABS car. Share this post Link to post Share on other sites
DamirGTI 367 Posted January 6, 2010 .. the top shaft is a 1.6 and bottom one is 1.9 Damir Share this post Link to post Share on other sites
humanz 3 Posted January 6, 2010 (edited) The teeth are an ABS sensor ring. This will work on an ABS or non ABS car. Cheers Tom. That's great to know. They're trying to get rid of old new stock. I got the message late and almost everything's gone! Managed to find this one driveshaft. Now if I can find a hub or two... Thanks for the pics Damir. It's a 1.9 shaft with an abs ring then. Edited January 6, 2010 by humanz Share this post Link to post Share on other sites
