fatony1
Gti6 Oil Level Sender...
fatony1
Is the Oil Lever sender needed on a GTI 6 conversion? The sender on my engine is broken and i just wondered if ill be OK remoing the sender and fitting a plug to the hole in the block?
Thanks in advance :D
not of any use unless you use the 306 cluster, or a VERY rare early 205 cluster, otherwise yes its not needed :D
fatony1
So its safe to remove and the plug the hole? :D
So its safe to remove and the plug the hole? :)
Yes, absolutely :)
Jamal
not of any use unless you use the 306 cluster, or a VERY rare early 205 cluster, otherwise yes its not needed :)
Was any 205 with oil level indicator? I didn't know that. When?
