Spiky
106 16v Engine In 205 Rallye
Spiky
been asked if i can supply a rev counter loom
but i'm not really clued up on the 106 engine.
it uses a twin coil system?
i have seem pics on google and notice it has a 4 pin plug.
and just wondering how it would get wired up?
NOT EXACT pin outputs, but just guessing
pin 1 Live
pin 2 earth feed from ecu for coil 1 + 3
pin 3 earth feed from ecu for coil 2 + 4
pin 4 unsue
anyone able to help?
from Autodata -
ECU pin 55 for cylinder 1 and 4, Pin 1 of coil plug, wire 110.
ECU pin 37 for cylinder 2 and 3, Pin 2 of coil plug, wire 111.
live to pin 3 from relay pin 13 wire number 1226.
Pin 4 of coil is connected to a suppressor that's bolted to the head.
same as a gti6 but only 2 outputs from the ecu to connect to basically, as its a wasted spark principle :)
Spiky
ok cheers :)
much appreciated
Sandy
Wire 426-429 is the Tacho feed from the ECU. It works with the 205 Rallye Tacho, but the 205 Rallye Tacho is really crap.
Spiky
hi sandy, he wants the gti clocks as he needs the speedo to read higher <_<
but cheers for the wire numbers ;)
