Spiky
Welding "eye" Fittings To Omp Cage
Spiky
is it ok or not ok to weld Eye fittings to the omp cage, to mount the harness from, instead of the old seat belt mounts on the rear floor?
*** flame suit ready and waiting ***
Atari Boy
Would it not be better to get the extra long eye bolts and drill staright through and bolt from behind as it were?
Spiky
yeah either is fine by me , but justing wondering it is a OK idea or not?
as technically you are altering the cage by drilling through, hence welding would put strength back in
Rich_p
It's been done on my Sparco cage
EdCherry
I wouldn't, loop the harnesses over a harness bar mate.
Spiky
got a picture?
can you explain?
as a harness bar is called a harness bar for a reaon :P
but thats not what i'm asking here is it? :ph34r:
EdCherry
Thinking about this again, maybe im wrong. I guess I myself am using this method but for my crotch straps on seat bars.
Edited by EdCherry
Spiky
Theres a few reason I wouldn't personally do it, one id go for is think of the material your welding too, 1.6mm thick steel or so. You wouldn't bolt your seat to it, or your cage infact so why bolt (or weld) eyelets to it and expect it to hold.
MSA stipulate 3mm thick spreader plates and minimum spread plate areas for a reason.
If you still want to use eyelets id still be using the floor pan at the correct angle and with the correct spreader plates rather than potentially making your cage illegal eventing wise.
dude, i think you need to RE-READ the original post as you are talking about something different to what i am
and not using the a harness still has me chuckling..lol
and using the floor at the correct angle? i'm not 2" tall :P
Matt180
It will be fine as long as the welding is done to a good standard!
Rich_p
Not the best picture but you get the idea
Spiky
cheers for that :angry:
